Eye Of The Robot-Series 4
quote:
Kody launches into hysterics as Intrigue makes the Heat Final!
Damn right! HAHAHA! :proud: I seriously wasnt expecting that. :proud: Awesome stuff.
Turbo Tails (21) vs. Intrigue
Well, lets see...Turbo Tails, as Frank mentioned, is unable to self-right with the flipper (its using the low-pressure one for this tournament)...I think Im going to try something else along with my usual tactics of hack to death - Im going to try and slide under Turbo Tails with the wedge attached to the axe, and then flip it with the axe by retracting. It shouldnt be hard as long as Ive got Turbo Tails in line. If it becomes a problem, grapple and push to pit.
But the best thing I have going for me is my lowness. Turbo Tails cant hit Intrigue with the rear bar as Intrigue is 15cm high. :proud: Take that into account folks. :wink:
Id love to see how Steve can counter this. :wink:
Added tactics: Get under Turbo Tails flipper, and push it into the wall. Lets see how badly I can smash TTs blade into the wall :proud:
(Message edited by kodster on March 15, 2008)
HEAT C
ROUND 3
Intrigue VS TURBO TAILS (21)
Yaaay! My inferior Paint skills are going to get me killed once more! :lame:
Not much I can do here. One thing Kody has overlooked, though, is Intrigues ground clearance. At a mere 1mm max, itll have a tough time overcoming the smallest of bumps - like my wedge. Tactics here are to charge the sides (preferebly at the corners) and try to get under that low, low ground clearance. If I succeed, keep charging so it rides up on top of Turbo Tails and into the spinning bar. Being short is no guarantee of safety from the tails, Kody. :wink:
Small mistake. That shall be changed later. :lame: Hopefully by the same time TT lowers its spinning bar. :wink:
Sound still be a good match, just relying on aggression. :)
One more thing: keep the axe out of range of that bar, for IT CAN get hit if I swing it down at the wrong time. :lame:
HEAT FINAL:
TURBO TAILS vs. INTRIGUE
Booth #1: Kody K
Booth #2: Steven M
Roboteers, stand by!!!
3€¦2€¦1€¦activate!!!
The robots seem to be tentative moving out into battle, with the Scottish fluffy robot spinning its hellish blade, and Kody with Intrigue sitting and waiting€¦now though he CHARGES AT THE FRONT OF TURBO TAILS! Steven stylishly dodges away that sign of peril, and bashes the front-right corner of Intrigue, but can€™t seem to push that far under underneath! However, Intrigue is stuck on the wedge, and Intrigue finds himself being escorted to the side, as Steven tries to push Intrigue onto the top of Turbo Tails€¦BUT HE CAN€™T! And now Intrigue fires his axe to force himself away from Turbo Tails! He now ends up side-on to Turbo Tails and BRINGS THE AXE DOWN! No notable damage is caused, but now Kody goes into reverses! And the layer of front fur is partly ripped off! Steven seems angered by this, and charges in once more, and gets under the body of Intrigue, and it performs the Highland fling on Intrigue! Kody doesn€™t hesitate when it comes to him self-righting, but Steven doesn€™t hesitate either, and bring the bar in to SLICE AT THE BASE PANEL! Nothing seems to have been sustained by Intrigue, and now he slices down the axe down once more, but Steven turns to get the bar into play on the axe! The axe hits the central spinning part of the bar, and the axe retracts, and Steven drives forward with the flipper, but he notices something - the bar isn€™t working! Steven now tries to get the flipper into play, but Intrigue spins away, and takes his chance to ram Turbo Tails over the flipping spike! Turbo Tails is now upside-down and it can€™t ALWAYS self-right! Intrigue takes this chance to hit the pit release button! Turbo Tails now fires its flipper, AND IT SELF-RIGHTS ITSELF! Steven is relieved, but Kody now gets his wedge underneath Turbo Tails, and the axe is brought down! Turbo Tails is now being moved across the arena to the pit, AND IS NOW ON THE EDGE! Turbo Tails is balancing, with the axe still in Turbo Tails! Intrigue fires the axe€¦AND THE AXE HAS COME LOOSE! Turbo Tails falls down the pit with a BANG! Intrigue rotates in the middle of the ring, and fires the axe in joy!
Result:
Turbo Tails (21) is clipped from victory!
INTRIGUE GOES THROUGH TO THE SERIES SEMI-FINALS!!!
Next Time:
HEAT 4
ROUND ONE:
Wedge Devolution (7) vs. SOR X vs. Iron Awe 5
Die-Ceratops ReInvertus (23) vs. Axe To Fall vs. FrenZy
Send in tactics, comments, predictions and a copy of SAW VI on DVD and a very large blowtorch :proud:
By the way, if Martijn and AJ would like to post in Axe To Fall 2 and SOR X, then do so, WITH YOUR TACTICS
*SHOCK. GASP. HORRO - JOY.*
Intrigues first tournament...and he gets into the semis! w00t! :proud:
Heh. good try, Steve. Youll get Sonics buddy into the semis...someday. :wink:
Wedge Devolution (7) vs. Son of Ripper Hex vs. Iron Awe 5
SoR...X? I dont see a SoR X, so Im assuming this is SoR Hex. :lame:
Lets see...Iron Awe 5 is a realie, but not to be underestimated. However, I can see the Steve/AJ team forming again here and trying to put Iron Awe 5 somewhere nasty...Iron Awe 5 out on a judges decision.
Die-Ceratops Re-Invertus (23) vs. Axe To Fall vs. FrenZy
Theres no Axe to Fall 2 right now either...but even if there was, FrenZy is still going out. :proud:
(Message edited by kodster on March 16, 2008)
MESSAGE
TO: Paul
CONTENTS: You are commended on your fights, which are very wooty. :)
END MESSAGE
Predictions:
Wedge Devolution vs. SoR Hex vs. Iron Awe 5
Someone will go outside the arena...Ill go for an upset and say SoR to be ousted.
Die-Ceratops Re-Invertus vs. Axe To Fall vs. FrenZy
FrenZy...bye. :proud:
Axe to Fall 1 it will be
Chris, shall we try to beat the crap out of FrenZy?:proud:
Youll probably want to write the fights before I get SOR X done so just stay with SOR Hex please. For tactics, Im thinking me and Steve team up and send Iron Awe OOTA?
I can see FrenZy going out in the other match too.
Can I ask AJ, which of the interchangable weaponry on SOR Hex are you using for this battle?
DIE-CERATOPS TACTICS
Yeah, what the hey. Ill go for the team up.
