So now Im going to start off with HEAT 1 now:
HEAT 1
Whirligig 4.0 (1) vs. Panicking vs. M2
Ramthrax 2 (17) vs. Seung Mina III vs. Disc-O-Inferno
Thatll be the line-up. I need tactics from Martyn, Dave, Alex and Chris before I can start Heat A.
HEAT 1
Just for the record, Im usually perfectly happy to let the writer decide my tactics, if I have any specific tactics I will post them.
In this instance, though because you asked, it basically amounts to ram stuff
Though Alex, if you are up for ramming Disc-O-Inferno to death with me, that could be arranged. :proud:
Yess. Paul thank you for giving me and Cyclone Force 2.5 a 1 way ticket to the next round. Tactics for Terrorhurtz. Whack Chaos 2 if 13 black can cause damage than its safe to presume that Terrorhurtz will cause a hell of a lot more. Just plain and simply massacre Chaos 2 with the big beefy axe.
Attack Panicking with the flipper and try and get it OOTA, avoid the champ
good luck writting without stats :p, anyway i will give u my stats when i am back at uni tomorow
Right. Me and Alex have agreed (over MSN) to team-up on Disc-O-Inferno. No way that disc is going to harm either of our armours. :proud: Ill flip it around and Alex can ram it around when Im not flipping. :proud:
quote:
because Aaron hates Brummies whos grandfather dies
Damn straight I do!
Name-Panicking Still?
SHAPE- Low invertible box
COLOUR- Yellow except for the lifting forks which are black
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
SPEED- 20mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 6 mm with out, the skirts are hinged so flop over when the robot is flipped. These can be removed before the fight if I wish them to be.
ARMOUR- 5 mm Hardox
MOVEMENT- 6 Vulcalon wheels to give extra pushing power
POWER- 4x S28-400 @ 24volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
SRIMECH- The robot is invertiable so doesn€™t require one. The robot can€™t rest on its sides, rear or front. Due to the skirts and that the sides are slightly angled. It can€™t rest on its front due to the forks.
STRENGTHS- Low to the ground, reliable weapon
WEAKNESSES- Kind of old design I suppose.
there is my heat a stats, more when i refind them.
quote:
Damn straight I do!
Me too.
