Hi,
I can say with all words what is fight against an axebot LH2 and LH3 :)
I use 5mm Aluminium 5083 and yes, it makes damages!! Never made "holes" on top, but left serious hits... ATM i'm in a 1-1 against LH, first time he hit the top and the ESC out of their place, entered on drum and obviously, destroyed ESC.
Last year i fixed the problem of the ESC, had a 3min fight against LH he completly discharged the air on top of Galactus, i won for points.
I can advise you (like grant said), if you use a minimun thick plate on top, dont worry about "internal" damages. HOLD all pieces inside and IF you can, to reduce "stress" on shafts of drivetrain use something underneath your robot lilke a "chock", so when he hit your top the "pressure" is dissipated to ground across the chock.
Im not worried about axebots, im worried with this:
Attachment 4420
