I'll let Ellis give a full run down on just how amazing Oilon is.
Ahh I see so what are your overall measurements?
500 x 338 x 113
Aluminium is terrible as a bearing surface as it is one of the worst metals for galling http://en.wikipedia.org/wiki/Galling. Using a plastic Oilon bearing will help a lot but I would definitely recommend using one of the harder grades of aluminium, polishing the surface AND lubricating it.
Is there any shaving available on the 500 measurement? The smaller you make it now the better you'll be at the end when your struggling with weight.
Again restricted by length of the bottle + motors unless I shorten it and put the bottles above the motors but will have to be taller again. The main body is 410 with an 'empty' wedge giving the extra 90.
http://i1298.photobucket.com/albums/...ps33a2b384.png
http://i1298.photobucket.com/albums/...psa7bbd161.png
Thanks for the advice Nick, I'm all new to custom transmission. I've been a drill motor guy so far so any advice is very welcomed. Is 6082T6 suitable?
hey! I've not looked through your hole build thread so im not too sure, but are you have just a single pair of wheels at the far back?
if you are i'd consider moving them at least to the middle or at least more forward cause you'll find it with handle horribly!
4 wheel drive would be cool, unless that's what your doing anyway in which case egnor me!
6082 is not a bad choice; its harder than 6061 so unless you can find some 7075 its worth trying. It usually has a rough surface finish so giving it a polish with fine sandpaper will be time well spent.
You need space for the main valve too, and the piping ain't small either.
Also, a wider machine is easier to drive. And the placement of the wheels is fine in the back. It's what we prefer.
I used 14mm 7075 super-polished wheel shafts and oilon for bushings. The belt tension puts huge sideload on the bushings and in my case, the oilon was a total flop. It's too soft. I ended up having to bore the bushings way oversize to loosen the belts to get to an acceptable amount of friction. I intend to run regular nylon next year. Bearings would be ideal but can fail, whereas a nylon bushing with low enough friction is indestructable, so not a bad compromise.
