Shape Steel Reign R3 Rochester
Havent seen it. This is why you need to describe the shape.
its kinda hard to explain so if its ok kody ill post it here k hold
http://www.flickr.com/photos/shainemata/416828562/http://www.flickr.com/photos/shainemata/416828562/
Couple things I also see wrong with this:
Drive: 2 x S28-400 Magmotors @24v
Power: 6 NiCad Battle Packs at 36v
Way too many Battlepacks. Go for 2 Battlepacks at 24 volts. The voltage for the batteries should be the same as the voltage for the drive motors.
Ground Clearance: 0mm on the front 5mm on both side and 0 on back
From the pic, It doesnt look like 0mm. Id say 5mm all around.
Dimensions in CM (Length x Height x Wide) 1.02m x 1.13m 1.13m
I cant decipher that, sorry. :proud:
Motivation: 4 inner 5.5inch wheels
Weaponry 2 vertical disk w/tool steel cutter spinning at 4,000RPM powered by 15HP Briggs & Stratton ETEK motor
Self-Righter: Invertible
Impossible. Cant be invertible unless the discs are smaller than the wheels or its 2WD, and that would make the discs very weak.
Implement some changes, please. :)
(and it would really if you didnt keep completely changing the entire vapourbot :P)
pls check
Name: Psycho Killer 2
Colour: grey
Speed: 14MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Steel
Ground Clearance: 5mm all around
Turning Circle: 0
Dimensions in CM (Length x Height x Wide) 1.02m x 1.14m 1.14m
Self-Righter: linear actuator powered bar on top
Strengths: Powerful spinner, good armour and speed
Weakness: hates flippers
Picture: Coming soon
there sorry for changing the stat
Name: Texas Chainsaw Massacre 2
Shape: Sewer Snake
Colour: Grey
Speed: 28MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Power: 4 12v battlepacks giving 48 volts total
Motivation: 6 inner Battle Tread Carefree Wheels
Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 110x75x25
Weaponry: Modular Lifter powered by 2 560lb Actuator the actuator weights about 9.7 lbs
Self-Righter: Invertable
Strengths: Powerful Lifter good armour, speed
Weakness: exposed wheels
kody can u pls do a cad
can someone help me with dimensions pls coz im getting confused Length width and height umm ok so length is the body front to back width is the sides and height is tall right?????????
...yes.
New version of Texas Chainsaw Massacre 3
Name: Texas Chainsaw Massacre 3
Shape: Panzer MK 2
Colour: Black
Speed: 20MPH
Armour: 6mm Titanium
Chassis: Hardox
Drive: 4 LEM 130s
Power: 4 x 30cell 36v 3Ah Sanyo NiCad Packs
Motivation: 6 Nightmare style wheels
Turning Circle: 0
Dimensions in CM (LxWxH): 1.24m x 0.76m x 0.46m
Weaponry: Panzer MK 2 style lifter powered by 2 560lb Actuator the actuator weights about 9.7 lbs
Self-Righter: Lifter
Kody can u pls do a cad for Texas Chainsaw Massacre 3
What does Panzer Mk 2 look like again?
When you base your shape on another real robot, it helps if you could provide an link to an image of said robot.
It looks like a large marshamallow, that has been sculpted into the shape of Panzer Mk 2.
(a non-invertible 6wd box :P)
