When will you be fixing them? :)
today
Should be good.
i hope
kody u have seen the Judge right Battlebots? wat do u think are the deminsion of its hammer
1. Can you please type with better spelling and grammar? Its really hard to read your posts like that.
2. The Judge has not given specific stats so I do not know the dimensions unless I e-mailed the builder himself, and I doubt I could find his e-mail.
3. There are several versions of The Judge, so I dont know which one you are talking about.
Name: Psycho Killer 2
Shape Son of Whyachi
Colour: CAD coming soon
Speed: 20PH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Steel
Drive: 2 x S28-400 Magmotors @24v
Power: 6 NiCad Battle Packs at 36v
Motivation: 4 inner 5.5inch wheels
Ground Clearance: 0mm on the front 1mm on both sides and 1mm on back
Turning Circle: 0
Dimensions in CM (Length x Height x Wide) 0.52 x 1.08 x 1.08
Weaponry 3 armed rotor w/ tool steel spiked hammers spinning at 4,000RPM powered by 15HP Briggs & Stratton ETEK motor
Self-Righter: none
Strengths: Powerful spinner, good armour and speed
Weakness: if its get flipped its dead
Picture: Coming soon
kody ive ditch trapulta Raptor umm anyways here is my new stat of Psycho Killer 2 can u check it kody if its right
oops forgot the color the color is grey
1. The speed might be a little optimistic, try for somewhere between 12-18mph.
2. The ground clearance needs to be higher; like I said before, youre not going to have a lot of mobility with 1mm ground clearance.
3. How exactly do the hammers work? (try and describe how theyre fixed on the robot instead of saying they work exactly like Son of Whyachis)
Otherwise fine. :)
ok ive changed my mind again :) new stat kody umm tell me if the dimension are ok coz i want the stat to be accurate etc
Shape Steel Reign R3 Rochester
Colour: grey
Speed: 14MPH
Armour: 6mm TI
Chassis: Steel
Ground Clearance: 0mm on the front 5mm on both side and 0 on back
Turning Circle: 0
Dimensions in CM (Length x Height x Wide) 1.02m x 1.13m 1.13m
Weaponry 2 vertical disk w/tool steel cutter spinning at 4,000RPM powered by 15HP Briggs & Stratton ETEK motor
Self-Righter: Invertible
Weakness: hates flippers
