If your robot has tracks, some tourneys allow you to have a 10% weight increase, meaning Dracula can weigh up to 110kg. :)
ok Daniel umm wats 110kg is that 300lb? coz i know 220 is 100 kg
242.5lbs :)
New Vapour Stat pls check tell me if its ok
Shape Cylinder
Color: See cad (soon)
Speed: 12MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive:. 4 X S28-400s at 24v each
Power: 4 x 24v 3.6 AH Battle Packs
Motivation: 4 omni-wheels
Ground Clearance: 0
Turning Circle: Zilch
Dimensions in CM (Length x Height x Wide) Unknown
Weaponry: spinning shell w/ tool steel blades that spins at 4000RPM powered by a Briggs & Stratton ETEK 15HP the blades speed is 150mph
Self-Righter: invertible
Strengths: powerful spinner, good armour and speed
Weakness: Rammers
Ruark,
Lose 2 S28-400s
All omni wheels for motivation means you will slide all over the place if you want to make a turn.
You need more batteries than 4 3.6Ah packs, with that beast of a motor for weapon and 2 S28-400s for drive.
And again no dimensions given.
yea about the dimensions im having trouble with it umm how many batteries should it use and wat kind of batteries?
Shape Cylinder
Speed: 15MPH
Armour: 6mm TI
Chassis: Titanium
Drive:. 2 X S28-400s at 24v each
Power: 6 NiCad Batteries at 24v
Ground Clearance: 0
Dimensions in CM (Length x Height x Wide)0.71 x 0.71 x 0.18m
Weakness: Rammers
ok there leo is it ok now
You have Width and Height the wrong way round, and youre robot would need to be taller than 18cm to fit the drive motors and the E-Tek in. Maybe something nearer 30cm?
The height could be improved, but only a little. Id say 20cm would be enough.
Ill get that CAD up too, Ruark, the one you e-mailed me. :)
ok kody umm CAD of Stay Alive k
