Can't be, it isn't parallel with the paving slab it's sitting on -Top wheel is, bottom wheel isn't. Either your wheels aren't or the slab isn't square.Quote:
On closer looking, it does appear slightly off yet explain why it goes to the right?
Apart from the wheels, looks good. Hopefully you should be able to get it running in a straight line if you move one of the wheels and motors round slightly :)
funny thing is its fine in reverse :)
I can explain that:
Tank steering works on the principle of two drives equally parallel & exerting equal forces.
Your right wheel is angled inward which means the robot pushing into a counter clockwise spin & being the dominant force, is drifting the robot right. Your left wheel skids.
When the robot reverses, the right wheel is angled outwards & is the weaker force of the wheels. Right wheel skids & the bot generally follows the left wheels direction.
If there's some handy and it fits, map your drive out on square/graph paper. It'll help affix your drive down to a minimum of drift error.
You could use someone like me on your team, Matt! :rofl:
You are in my team ceri... :proud:
i'm impressed with how good your grabber looks!
What were you expecting? :D
The claws from point to point are 62cm btw :)
a dog with a cardboard box covered in tin foil on it :proud:
looking nice
Are they FW's?
