Re: Hard Time's build diary
Ok
Team Magma is making has ordered most of the parts for virus.
The plastic has arrived today.
little Q,
I want a spiining disk for kilo bot approx 170mm in diameter and want to weigh under 300 grams what thickness should I use and what material (i'm was either going to use Hadrox 450m, P20 or Grade 5 Titanium)
Find the density of the material you want and do the maths to calculate the volumetric size of your bar and you have your weight.
For comparison, the bar on Spinza is 270g, some sort of steel, and 320mm x 45mm x 2mm.
It's far too heavy though, components alone for Spinza weigh a Kilo.
got some bits for virus my kilobot...
got
2x MFA 30:1 gear motors
brushlees spinner motor
spinner motor ESC
wheels
ordered..
11.1v 1000mah lipo
also got some bits for Twister my FBS antweight.
How much (roughly) is a 63mm bore 75mm stroke cylinder meant to weight?
Looks much better invertible
