The Crash & Burn Tournament 3
Its better an calling it Air-Gene or Carbo-Gene. It doesnt have the ring of Nitro-Gene :proud:
Kody, Im sorry youre disappointed with me, and I know me suddenly deleting my first 5.0 stats and going back to no. 4 was idiotic, but Leo has ticked everything now, so it should be fine.
And about the Nitrogen thing, all Ill say is I was looking at GeForce 4.0 when I made the stats for it, and I decided to go down the Nitrogen path.
(Message edited by paulc on August 13, 2008)
Dont clone the master of clones. :wink:
And WHAT ARE YOU GOING TO DO ABOUT THE DIMENSIONS???
Im doing the changes on the ZED board,as I dont want to clog up this thread with criticism. Ive made it wider, as I only shortened it by 1cm from the previous version, which isnt too major, so its 63cm wide, not 57cm wide.
Youd best do it in the How Can I Improve thread, where we can SEE these changes.
quote:
Kody, Im sorry youre disappointed with me, and I know me suddenly deleting my first 5.0 stats and going back to no. 4 was idiotic, but Leo has ticked everything now, so it should be fine.Well lets not get to exited here. I just noticed you increased the bottle size. I said you would be hard pressed to fit even 1 bottle in, and now you switch to a bigger one.
Do yourself a favour. Draw a rectangle, in scale say 5:1 or so. draw in the ram, motors, wheels, batteries, bottle, and gearboxes. make sure you get the scale right on those. You will find that fitting it all in there is not going to be that simple.
1 x 1.5kg bottle - 10 flips :lame: 10 is probably enough flips to last a match, so that should be fine :)
http://www.fightingrobots.co.uk/discus/messages/760/13309.html?1218659259http://www.fightingrobots.co.uk/disc...tml?1218659259
Here Paul! :P
Ive just posted there! :proud: - This is a disasterous scenerio :rofl:
Right. Keep the discussion there until the stats have been made legit.
Ah yes, forgot to mention...at second glance, Frank, your vapourbots dimensions seem quite small as well...explanation?
(Message edited by kodster on August 14, 2008)
