haha, sorry, Im very unfarmiliar with RW Series 2 :)
SHA will take the route that has the ramp
*considers putting ramps on all the routes to confuse Martijn*
Anyway...
FIRST, FROM SUFFOLK, ORKA MARK 4!
A six wheel drive marine beast armoured in titanium cladding, Orka has CO2 powered pneumatic weaponry consisting of a bucket scoop with a clamping arm, and a dorsal fin which extends to self right the machine. It has six wheel drive from S28-400 Magmotors which give it good traction and a maximum speed of fifteen miles an hour.
FROM MABLETHORPE, TRAX!
The name says it all, a tank tracked real machine with a front wedge scoop for getting underneath opponents and drawing them on to the front hinged pneumatic flipper bar. Trax runs from Magmotors and 4QD speed controllers with tank style steering, and is protected by high density polyethylene armour which is good for withstanding blunt impacts.
FROM TORONTO, SUPER GORE EVO!
Another tracked robot, Super Gore Evo runs on Vulkalon and titanium treads driven by Lynch motors and NiCad batteries at 36v, giving a top speed of eighteen miles an hour. It has skirt-like plates on each side to deter wedges and the main weapon is a set of interchangable horizontal hydraulic jaws that clamp or damage with a tip force of four tonnes.
FROM HOLLAND, SHEER HEART ATTACK!
More tracks here, from a robot that gains an advantage in battle by driving over an opponent and getting the front twenty two kilogram drum into play, spinning at 5000rpm. The tracks are titanium and allow the robot to be invertible, and are driven by 48v Lynch motors at speeds of fifteen miles an hour with the robots armour being 6mm titanium with bars to protect the tracks.
FROM ENGLAND, SON OF RIPPER HEX!
SoR Hex is an invertible box design with wedges and titanium skirts on all sides to get under opponents, protected by Hardox armour and powered by Lynch motors driving aluminium and Vulkalon wheels at 12mph. The weaponry consists of a front CO2 low pressure rear hinged flipper with interchangable rear weapons including a horizontal or vertical spinning bar, a saw blade or an armoured ramming plate.
FROM ENGLAND, STORM II!
Finally, tonights fastest and most well known robot, a realie with Lynch motors, custom speed control and six wheel drive underneath titanium armour. It relies on its speed and ramming power for weaponry, but also has a Magmotor-driven 4 bar lifting arm machined from aluminium, runs inverted, and has survived some of the most powerful spinners ever in the past.
Gaountlet up later, get your tactics in.
-2>*whispers* ...wheres Storm II from again?
damnit...
Joey... when I said Id enter Sheer Heart Attack I meant Sheer Heart Attack 2...
sorry _
Middle ramp...shove past Dead Metal, my claws are lower than his.
I was going to ask you about that as well...I did guess that maybe you entered SHA 2 instead, but I went on the safe side in case you really meant the original one.
Shall I replace it? Theres not that much difference between the two, so Id allow it.
middle for trax too. nothing will stop it in its trax. will just plow under everything in its path.
very kind of you Joey, thanx :)
lol, and why is it everyone reperesents his city except for the Dutch guy :wink:
I never noticed it was on your profile before, and I dont know if I can consistently spell it :P
My scoop should easily be able to bulldoze down the wall, so Ill go for the centre route. Backwards over the ramp as well.
BTW, Storm 2 is from Ipswich, according to its last RW appearance.
I plan to drive along the ram-rig, and just push things to the end.
