New FW database (new robots)
Well, no name yet and also not finished yet, but here are the first previews of our new feather: <
http://www.team-rcc.org/images/RCCHittersmall.jpg
http://www.team-rcc.org/images/featheraxeframesmall.jpg
The frame is all Laser cut and welded up today. The rest is on the way.
A few specs:
Drive, 2x speed 900 with 90mm wheels
Weapon 1x speed 900 21.6:1 gear reduction
Scorpion XXL for drive
Custom H-bridge for weapon.
Voltage tbd.
Certanly looks like its going to be entertaining in its fights.
Status: being constructed
Drive: 2x 700 size Brushless motors custom wound (by me)
Topspeed: Approx. 45 Mph
Power: 2x A123 6cell 2300 mAh.
Speedo: reprogrammed controller (classified brand)
Armour: 12 and 4mm Hardox 450
Weapon: 17KJ Rambot
Post in error (wrong section) Sorry:uhoh:
(Message edited by scorpion on December 10, 2008)
well its going to be under 8kg by the looks of it so might be able to have 2, but this one is costing about £500
Status: Under construction
Drive: 2 golf caddy motors
Topspead: 15/20 mph?
Power: 3 24v alarm batteries
Speedo: TBA
Armour: 3mm Ali
Weapon: Full Body Hammer/Thwack Bot
Sounds like two quite extreme robots from both Craig and Matt.
Hopefully pictures will be posted soon.
Craig, I have no idea how you got a robot with a combination of 12 and 4mm hardox under 8kg. What speedo you planning to use?
Matt that sounds rather mental. What are these gold caddy motors? Sounds more more like a heavy setup.
What batteries are you using? The alarm batteries are usually 12volt SLA around 2amps. How do you plan to use three?
Its the amount of hardox Marco and the fact that i havent weighed it complete (as in not weighed it in finished) but i calculate it to be 7.9kg total
Controllers, im not willing to say just yet same as Anto XP but bigger
Craig- good luck trying to get brushless motors with the start up tourque to power a decent pusher.
Sounds like your going down a dodgy road already- i tryed using small name brushless stuff.. the rating on the box isnt realistic and the speed controllers they suggest with the motors are no were near capable enough for robot use most of the time.
What brand are the motors? Its worth going with a big named highly suggested company that are well known within the RC helicopter or plane market- i tryed some one off motors first in 360- they worked brilliantly.. once. then burnt out. And the speedos the suggested were 1/3rd of the power ive had to upgrade to now.. the first set of speedos went up in smoke before it reached 10rpm.
Im on my 5th and 6th esc now. Brushless stuff for antweights isnt hard.. trying to get it to work in a bigger weight class is a pain.
