Just a note starfire the 3rd is devons robot and frank is replacing devon due to the clone story
Thanks for the heads up Martyn.
LIAR!
*Wonders if scott is serious or not*
Does anyone know which of my competitors are replacing Starfire?
Grabbit Advance.
Right. Well, these tactics are assuming COH is unchanged from when entered in NSBFL 7.
If hes using the axe setup, then if its powered like Terrorhurtzs, it wont be strong enough to do much visible damage to Ti armour. However, that doesnt mean its something I want to be hit by, so Ill keep the claws closed and lowered so I can just shoot straight under him and lift him. When Im lifting him, he wont be able to hit me, so Ill roll him over, then grab him while hes on his back, lift him again and try to drop him somewhere he doesnt want to be dropped.
If hes using the lifter, put the claws flat on the ground and get under him from anywhere, then see above comment for what I want to do to him:proud:
I think using the hook wouldnt work to the best as i doubt i can get a good enough hold of him so it looks like i will be using the axe setup.
I will be able to selfright quickly if he flips be and will try to avoid his front and ram him around and pit him and smack him as much as possilbe with the axe.
My armour should survive Scotties axe and so I will work out the set-up for seggy once scottie has posted tactics :proud:
Right.
Left.
Back and Forward :proud:
Segs weapon will be the passive 100 kg, I have a speed advantage and so will get around the side and push sideways into the arena wall/hazards/pit release pit. Be like Tornado and dont give up, dont allow mr scott to be mr scott
