Uh... Longer and lower rather.
david here is a pic of old storm that i got from a Team Storms site my vapour is exactly the same coz my little brother wanted me to have a vapour just like old storm its he favorite robot here is the pic http://www.teamstorm.com/storm/gallery/storm.htmhttp://www.teamstorm.com/storm/gallery/storm.htm
The original Storm was a fun robot to watch. We bought its original hydraulic ram for a couple of years. Its gone now.
(Message edited by leorcc on June 12, 2008)
I seem to remember seeing the original Storm fighting The Dome once. It won, but The Dome did last longer than it did against Diotoir.
Heres my other stat can guys check it even the Dimensions coz im not sure if the Dimension are right
Name: The Grudge 1
Shape: Suicidal Tendencies
Colour: Black
Speed: 18MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x S28-400 Magmotors @24v
Power: Four 12v, 16Ah Hawkers
Motivation: Custom Made titanium tracks w/ 1 inch spikes for girp
Ground Clearance: 2mm
Turning Circle:0
Dimensions in CM: 1.38m x 0.74m x 0.70m
Weaponry: Pneumatic stinger powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2200 joules at end of swing
Self-Righter: The Stinger has a spike on top that pop out to self right the machine Strengths: Powerful weapon, good armour and speed
Weakness: exposed tracks from the back
You really shouldnt put spikes on tracks, it just negates the purpose of tracks, a lot of surface area. If you want to improve traction, use rubber strips on the tracklinks or use rubber tracks.
See Trax vs Storm 2 for details, Trax was just sliding all over the place.
ok but wat about the dimension are they ok
70cm high is quite high (2.3 feet)
so the Dimensions in CM should be 1.38m x 0.74m x 0.2.5m
