Paul: http://www.youtube.com/watch?v=04V1HYyFP8Mhttp://www.youtube.com/watch?v=04V1HYyFP8M
Kody: finally someone who understands why battery stats are important. :)
Well, Leo, considering with no batteries Id have a classic 80kg heavyweight without the ability to move... :)
Is this vapour OK?
http://strickenone.proboards99.com/index.cgi?board=teamww&action=posthttp://strickenone.proboards99.com/i...ww&action=post
Liam: LINKING FAIL
Expand the dimensions a little. :)
And yeah, the link is phail. :P
http://strickenone.proboards99.com/index.cgi?board=teamww&action=display&thread=297&p age=1http://strickenone.proboards99.com/i...isplay&thread= 297&page=1
Strange...
Say how close to the ground the heads are. Because it might end up being like Choppers weapon that could barely hit anything from what I recall :P
Or Son of Whyachi, who went AWOL in Season 4 of Battlebots. :P
Guys tell me wat u guys think about the new Predator 2
Shape: The Judge (battlebots)
Colour: black w/ grey strip on both sides
Speed: 25MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive: 4 S28-400 Magmotors @24
Power: two 16AH 12v Hawker Genesis SLA batteries
Motivation: 6 9inch BattleTread Carefree Tires
Ground Clearance: 0mm on the front 10 on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 1.24m x 0.74m x 0.70m
Weaponry:Pneumatic Hammer powered by a 4 bore, 12 stroke air cylinder at 200 PSI and can produce about 2200 joules at end of swing
Self-Righter: axe
Strengths: Powerful axe, armour and speed
Weakness: Hates Spinners
How are these classic heavyweights?
Dont ask why I built them, its a secret!
Delta-Rex (Classic HW)
Weight: 80kg
Shape: Reverse cut-off wedge with a scooped front
Dimensions: 75 x 75 x 28
Motivation: 2 x go-kart wheels at the front of the robot, internally mounted
Power: 2 x Litton motors overvolted to 36v
Armour: 3.25mm hardox sides, front, rear and top, 4mm 7075 aluminium base
Weaponry: 1)T-Minus style flipper on the front of the robot, the arm running down the wedge. It is powered by 2 x 2kg co2 bottles and has 1 x 100m ram at 500psi.
2) At the rear on the cut-off part of the wedge there are two hardox tungsten tipped ramming spikes.
Top Speed: 20km/h
Ground Clearance: 0 at front due to scooped front and flipper, 8m at sides and rear.
Turning Circle: 0
Srimech: The flipper
Colour: Gold with name painted vertically in sapphire on the flipper
Strengths: Powerful weaponry
Weaknesses: High ground clearance around sides and rear
Bambi (Classic HW)
Weight: 80kg
Shape: Box wedge
Dimensions: (with claw open) 75 x 110 x 20
Motivation: 4 x vulkalon tyres
Power: 2 x S28-400 magmotors powered by 4 Nicad battlepacks at 24v
Weaponry: TAN-style claw on a lifting arm. The arm runs for the full length of the robot and is powered by a linear actuator. Each arm of the claw is powered by a 2kg co2 bottle and a 80mm x 40mm ram at 250psi. The idea is to grab opponents, then lift them. The claws have serrated edges to hold onto opponents better.
Top Speed: 15mph
Ground Clearance: 6mm
Turning Circle: 0
Srimech: The arm
Colour: Dark Blue
Strengths: Good weaponry
Weaknesses: Ground clearance
