guys im a beginner so im going to do easy stats first ok but u guys to check them pls
Pain (new version lifter)
Shape: Sewer Snake
Colour: Grey
Speed: 28MPH
Weight: 220lb (100kg)
Armour: 5mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Power: 4 12v battlepacks giving 48 volts total
Motivation: 6 Battle Tread Carefree Wheels
Ground Clearance: 0mm on the front 10 on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 40x32x10
Weaponry: Lifting Tusk powered by Heavy-Duty Motion (1000lb) actuators that weights at 10,2lbs
Self-Righter: Invertible
Strengths: Powerful Lifter good armour, speed
Weakness: exposed wheels
I still think 28 MPH is going to give you control issues. Maybe go from 4 LEMS to 2?
This looks like it could be an effective spinner killer Rurak, but 5mm Titanium is pretty flimsy, so I suggest that you make it a monocoque with a Hardox chassis, as thisll keep the 5mm Ti on for a long time.
Another thing is make it 5mm Ti/V alloy, as its not much heavier and its also a lot tougher.
Dimensions are a little off - 40x32x10cm is closer to featherweights when it comes to size. For something very similar to Sewer Snake wed be talking about 120x90x20cm.
And am I missing something with titanium? 5mm titanium flimsy? I saw a 6mm piece on Tiberious at the FW champs and it was rock solid. I also heard how much of a pain in the asp (:wink:) it was to cut that 6mm piece so I think 5mm would be fine.
As a chassis material, I imagine it would be adequately strong enough, especially if a sturdy construction technique is used (e.g. interlocking parts, reinforced by welds - seemed to do the job well on an Aussie FW undercutter)
Youre missing the point that the laws of physics do not necessarily exist in vapourbot land :P but 5mm Ti should give adequate protection against most things, the only thing you really need Hardox monocoques and Vanadium alloys for is Aaron. :proud:
LockJaw Epedemic: Good and in weight, yes; effective, perhaps not. Stinger wasnt exactly easy to control, and youre using a weapon that needs more precision than Stingers did in a smaller attack area, so something to think about there.
Pain: Dimensions are off, as Jamie said; other than that it seems fine, decent SS clone.
i mess up on the dimemsion umm here are the dimension k 1,14 x 76 x 46m and the armour is 6mm TI
my other vapour
Shape: Suicidal Tendencies
Colour: black w/ grey strip on both sides
Speed: 25MPH
Armour: 6mm TI
Chassis: Titanium
Drive: TBA
Power: Hawker 2v-5amp-hour cells
Motivation: 6 6.5 inch inner wheels
Dimensions in CM (LxWxH): 1.24m x 0.74m x 0.70m
Weaponry: 2 electric powered axe powered by 2 Briggs & Stratton electric motor at 60v 9 Ah bank of Nicads the axe is made out of S7
Self-Righter: axe
Strengths: Powerful axe, armour and speed
Weakness: Hates Spinners
QUESTION:
B42-500s, can we use them or not, and if so how much power do they produce? Flick of the Wrist and Mega Monsoon are still using them.
I believe Ramthrax has them too :P
