ok guys umm scrap the stat on Pain ill go with a spinner coz hydraulics are to hard k
ok guys here is the new stat of Pain umm ive change the stat of pain coz hydraulics are hard to much for me think think anyways ill stick to spinner,lifters etc except crushers
Shape: Steel Reign (battle Bots R3)
Color: Grey
Speed: 18MPH
Weight 220lb (100KG)
Armour: 10mm Titanium
Chassis: Titanium
Drive: 2 S28-400 MagMotors @24v
Power: 2600 NiMh
Motivation: 4 NPC-PT444 10 inch flat proof wheels
Turning Cirle: 0
Dimension in CM (LxWxH:) 85x80x25
Weaponry: 2 vertical 9 bladed disk powered by a Briggs @ Stratton World Formula Go Kart Engine at 12v
Strength: Deadly weapon , good armour and speed
Weakness: Hates Flippers
Self-Righter: Invertible
guys tell me about this stat pls and thanks for helping me and being patient im slow on learning coz i have learning disability but it didnt stop me from doing wat i like to do
Another case of randomly picking parts and just duct taping them together.... No research into what they do and how they work....
quote:
Weaponry: 2 vertical 9 bladed disk powered by a Briggs @ Stratton World Formula Go Kart Engine at 12v Petrol Motors now run on 12v? I guess Ill have to start charging my car instead of putting fuel into it. The motor your stating
http://www.briggsracing.com/display/...d=101374Briggs
ok im replacing the weapon motor to an Etek-RT Motor (so the speed of the weapon is 3700 @ 72v) most of the robot that are spinner have an etek motor to power the weapon can u do a last check on my stat again sorry about this guys i keep messing up on stats
10mm Ti all over is too much, you would end up with over 70kg of Ti which leaves you no weight left for motors and discs or batteries or electronics.
Make it 10kg front and back (because thats where its needed the most) 6mm on the sides and 4mm on top. That will leave you with 55kg of Ti, so a little more breathing room to fit the rest in.
2600 NiMh, I presume 2600mAh NiMh cells. For NiMh those kinds of capacaties are low, for a heavyweight I would only use 3000 mAh or more wether it is NiCad or NiMh. Also you dont stat how many packs (a pack is either 6V, 12V or 24V) you would use back to back (that is called in series, making the voltage go up (12+12+12+12=48V), then how many of these series you would put parralel (2600mAh is so low your batteries would melt or blow up if you put a LEM or Magmotor or Etek on them, let alone 2 Magmotors and an ETEK at the same time). By putting your series parralel you increase the amount of current they can deliver. So you can power stronger motors without burning them out.
In your case, 36V would be sufficent, mAh I would say 11000 at least. so 3 12V packs in series (36V), 5 of those series in parrallel(2600*5=13000mAh). That is roughly 10kg worth of batteries (150 cells in total of 70 grams per cell).
for some reason alarm bells are ringing. anyone else?????????
Im not 100% sure what you mean, but I am somewhat wary at this point...
You mean it might be tim e for some Male Kram?
Hows LockJaw Epidemic? Its kind of complicated...
http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=190&p age=1http://strickenone.proboards99.com/i...teamww&thread= 190&page=1
