Why, it appears that I am now off for my Easter hols. Time for another round methinks! :D
HEAT C
ROUND 2
SEMI-FINAL 1
BACK TO ROCK III Vs NITRO-GENE 5.0
House Robots - Dulcy & Scream
Roboteers, stand by...
3...2...1...
ACTIVATE!
Both competitors are off to a flying start, colliding in the centre of the ring! It appears Back to Rock III is just the lower of the two as it squeaks under Nitro-Gene's flat front! Martijn activates the arm and begins to lift and push the PTT newcomer! Unfortunately for him, Nitro-Gene slips off the large lifting arm and darts away to safety! Back to Rock stays on its tail, aiming to charge the rear corners and penetrate those defensive skirts! Martijn's having a hard time however as Nitro-Gene is slightly the quicker of the two and he can't quite seem to catch up! Nitro-Gene leads Back to Rock all over the arena, only coming to a halt when it heads up north and crashes into the Void Activation Button! The siren echoes o'er the warzone as Back to Rock finally catches up and slams into the newcomer's rear! Scraping underneath, Martijn immediately sets to work chewing up the titanium skirts and lifting Nitro-Gene's back end off the ground! His robot tightly pinned against the Button, Paul fires the flipper, hoping to hop his way to freedom! The gambit works and Nitro-Gene lands back on its wheels, skirt slightly sliced! Back to Rock nudges its opponent, but can't get in another hard shove before the newcomer zips off again to the arena centre! Martijn grumbles to himself and the chase is on again!
In no time at all, Back to Rock and Nitro-Gene are back together in the middle of the ring! Back to Rock manages to clip Nitro-Gene's side, causing a small burst of sparks as the saw hits a corner! Nitro-Gene immediately spins round and bumps Back to Rock in return! Martijn attempts to get underneath again but Nitro-Gene backs off and swoops in for another charge! The two machines collide and bounce off each other! Quickly recovering, both bots end up side-by-side and begin to spin, locked together in a true dance of death! Paul decides to take the lead as a sharp turn from Nitro-Gene allows it to scrape under Back to Rock's side! The newcomer's flipper immediately fires, sending Back to Rock barrel-rolling across the arena and back onto its wheels with a deafening clatter! No sooner has Martijn recovered than Nitro-Gene returns to pile on the pressure! Another pushing match sees Back to Rock getting back underneath its rival! The lifter rises and the saw whirls, but Nitro-Gene manages to jerk away before being fully swept off its wheels! Martijn is just lowering the lifting arm when Nitro-Gene plows underneath! The newcomer pours on the gas and charges towards the nearby eastern wall! Back to Rock tries to push back when the flipper fires once again! The veteran tumbles over the fence and out of its second successive PTT!
CEASE!
Back to Rock rolls back to square one. Bring on Mk IV, I say! :proud:
NITRO-GENE 5.0 GOES THROUGH TO THE HEAT FINAL!
HEAT C
ROUND 2
SEMI-FINAL 2
ACHILLES (1) Vs INFUSION
Today, Achilles will be using its hydraulic set-up, complete with grabbing claw.
House Robots - Fawkes & Scarlek
3...2...1...
ACTIVATE!
Away we go again and it's a race to the Void Activation Button! Looks like both bots are keen to end this battle ASAP (and not me, honest!). Achilles draws ahead first but a quick 'turbo boost' sees Infusion slam into the Buttom first! As that all-too familiar klaxon does its stuff, Achilles arrives and clips Infusion as it makes its escape! The two briefly tustle in the corner, ending in Infusion darting away for a clear one! Achilles follows suit and the duo lock horns again near the Launchpad! Infusion's great manoueverability proves key here as the newcomer crashes into Achilles' side! While failing to penetrate the skirts, Aaron's still managed to knock the champ for six! Keen for payback, Achilles clips Infusion again with the lifting arm as it manouevers for another attack! It's Alex's turn to go full throttle now as Achilles powers under Infusion's side and rushes towards Fawkes' CPZ! A well-timed 'turbo boost' however thrusts Infusion to safety...and the eastern wall! Achilles leaps in for the kill, ramming the newcomer and finally getting a grip with the little claw! The lifting arm begins to work its stuff but Infusion's wheels are spinning like there's no tomorrow and it seems the champ's hold is beginning to weaken! Achilles tries to drag Infusion back into Fawkes' CPZ, but a bump from the House Robot only serves to weaken the grip further! Infusion quickly wriggles free and dashes down the arena for a clear run! Achilles remains hot on its heels (Ha-ha-ha) and catches up in no time! Aaron attempts to boost out of harm's way, but the reigning champion sweeps Infusion aside and knocks it into the eastern wall! Desperately trying to keep the rear spinner going, Aaron boosts once more as Achilles makes to grab hold of his revolutionary rammer! It's not much but it's enough to escape the champ's grip! Realizing how close to the Void's corner they both are, Aaron spins Infusion round and meets Achilles head-on! The newcomer boosts, nearly forcing its experienced opponent over to one side! Achilles fights back, scraping underneath the 7.5mm ground clearance at the side! Bringing down the claw and lifting the arm slightly, Alex's ancient annihilator surges down the ring towards the Void! Aaron hurridly attempts to escape, but in the blink of an eye, Infusion plummets into the Void and the great Greek warrior keeps his title for another day!
CEASE!
Infusion gets distilled from the tournament. Try boosting your way out of the Void, Aaron. :proud:
ACHILLES (1) GOES THROUGH TO THE HEAT FINAL!
Later on...
HEAT C
HEAT FINAL
ACHILLES (1) Vs NITRO-GENE 5.0
Thoughts? Tactics? Party at my place?
Thank you. :)
