Oooh... Someones been playing with Flamingo :P
Ill get some vapourbots sorted out in the next few months...
Looking good...those look more like flywheels than angle grinders though :P
Me: Yes, there are angle grinders in the arena, along the wall of each wall, but not those crappy ones in Robot Wars that didnt do damage. . The discs are 25kg and have 2 7.5kg hardox teeth to destroy with. They spin at 1250rpm and dish out about 50kJ a hit.
:P
Ah. My bad :P
How about Team Simpsons?
Thats not an angle grinder then :wink:.
All right, and in your view what EXACTLY is an angle grinder? A disc that spins at 0rpm? Because thats what it looks like in RW. :P
I edited my entry.
Black Death
Shape: Box with wedge
Weight: 100kg
Armour: 6mm Hardox
Dimensions: 90 X 87 X 30
Drive: 2 X 24V LEM-130
Wheels: 2 Aluminum Hub Wheels with a thin layer of urethane rubber
Top Speed: 19 mph
Batteries: 4 X 24V NiCad Battlepacks
TC: Zero
GC: 0mm on front, 5mm on the back and sides
Weapon: Flipper powered by 2 X CO2 Fire Extinguisher Tanks, 13kg Laser-Cut, Horizontal Flywheel with 4 curved teeth on the back powered by a single LEM-170, spinning at about 4000RPM
Srimech: Flipper, Flywheel on the back and sloped sides prevent it from getting beached.
Strengths: Flipper, Disc, Good Pusher
Weaknesses: None Hopefully
Walk Don€™t Run 2
Shape: Circle
Weight: 130 kg
Armour: 12mm Hardox for the ring, 4mm Hardox for the top and bottom
Dimensions: 89 X 89 X 20
Drive: 4 Shuffling Pads with 6 Legs with vulkalon rubber
Batteries: 5 X 24V NiCad BattlePacks
TC: Zero
Top Speed: 15 mph
GC: 5mm
Weapon: A 38kg Spinning ring with 4 X 4kg Pussycat-Style Teeth, curved, Spinning at 2200RPM powered by a 36V LEM-170.
Srimech: Its Invertible
Strengths: Good Weapon, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH!!
Weaknesses: Doesn€™t Like Flippers
(Message edited by samuel3764 on April 02, 2008)
Shape: Circle
Dont you mean cylinder? :) Also those dimensions seem quite compact...:wink:
Just a helpful pointer. :)
Oh, and Aaron...no offense, but I am kind of hoping to get this whole thing kicked off within a few weeks, so maybe if you could have those new vapourbots planned for C&B3, thatd be great, but for now, would it be possible to enter some of your older designs if you havent got new ones up yet?
Angle grinders use abrasion cutting wheels, and cut by friction. They have no teeth as such. All the sparks are actually fragments of metal flying from the cut.
