How Could I Improve...
Class: Heavyweight
Armor: 5mm Titaniun Weight: 100kg
Top Speed: 28MPH
Batterie 4 12v, 16Ah hawkers
Motors: 4 48v LEM130s, it uses 4 12 volt battlepacks, giving it about 48 volts total.
Drive: Chain, 6 wheel drive
Steering: Tank
Weapon: Invertible lifting tusk powered by 2 220lb (100KG) motion actuator
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
quote:
Srimechs arent mandatory. Typhoon 2 won series 7 without one, and beat a number of flippers en route to doing so.
true Frank, but lacking a srimech should be considered a weakness still :P
will do the CAD when I find the time
bout that guys check it out
here guys my new version of The Undertaker
Class: Heavy Weight
Weight: 100kg
Top Speed:15 MPH
Batteries: 2600 NiMh
Drive Control: Victor
Drive Motors: 4 S28-400 Magmotors driving 6 TW W238H-150-44H Wheel at 36volts
Weapon:2 20lb spinning disk with cutters
Weapon Speed: 3700RPM @72V
Weapon Motor: Etek-RT Motor Motivation: 6 NPC-PT444 10 inch flat proof wheels Strength: Powerful Spinner, good armor, speed
Weakness: none Self-Righter:2 low pressure Co2 powered bar on top of machine can self righted 30 time
2 incarnation of the undertaker pls tell me wat u guys think
so wat u guys think umm need more work
I dont think you need to state speed controllers *awaits inevitable backlash from Craig, Leo, etc. :P* and 10mm Ti with two Eteks and four Mags is overweight.
Armour: 6 Class: Heavy Weight
Weight: 100kg
Top Speed:15 MPH
Ive fix it i hope its right
I dont really state them in my specs but I do account for them in my designs. I dont really expect you to. Batteries is another matter.
Ruark: I need sizes of your robots too (length, width, height).
Lose the battlepacks in Ultimate Killing machine, 4 wont cut it and you already have Hawkers.
Undertaker is hugely overweight.
