joey so my stats is ok or still needs some work can u pls tell me wat is missing:)
here is Ultimate killing machine
Class: Heavyweight
Weight: 100kg
Top Speed: 37MPH
Batterie 4 12v, 16Ah hawkers
Motors: 2 12 HP Briggs &Stratton ETEK€™s
Drive: Chain, 6 wheel drive
Steering: Tank
Weapon: Invertible lifting tusk powered by 2 motion actuator
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
tell me wat u think guys
Too fast to be really controllable, and from what Craig tells us Eteks really arent worthwhile for drive motors. Stick to Lem-130s, theyre also a lot lighter so you can use that extra weight to maybe bulk up the armour a little.
i think i got the second one right pls tell me
ok so here is my new stat
Class: Heavyweight
Weight: 100kg
Top Speed: 28MPH
Motors: Six Dustins, all set to 34v
Steering: Tank
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
here it is again ps check
can somebody tell me wat they think on Ultimate Killing machines stats pls
Again I suggest you use LEM-130s at 36v for the motors
Well for one thing you dont have any armour, and generally you just need more detail throughout:
Describe this lifting tusk describe the wheels, describe the chassis.
Also 12v batteries yet 36v power?
You also need ground clearnance, and while I presume lift is refers to the weapon you need to make it more clear.
A picture of some sort would help too.
Its pretty hard to guage effectiveness until you fix this stuff.
martijn can u do a CAD for The undertaker 1 the full stats is in Zlaying Every Day Forum
Hi there and welcome to the forum.
Jeez Ive only been away for a couple of hours and there is already a list a mile long. :)
Well lets look at your stats:
6 dustins to move a heavy is possible, but i doubt you will achieve 28mph on them. They will probably burn out way before then. On 36V you would get about 20mph on the 26cm wheels (I happen to use the same wheels as Sewer Snake in RCC2) And I wouldnt recommend going any higher.
34V is a really weird number to run motors on. 36V or 24V is pretty normal sometimes 48V (but thats not going to happen with Dustins),it usually goes in multiples of 6.
I dont see any mention of armour, so i would need that.
Id say its a work in progress. Keep it up.
