The construction of your sentence makes no sense ...try again.Quote:
Originally Posted by Thunder arrow
I guess that your missing a word e.g. regulator?
OK
What is the average weight (in kg) of a 150 psi/10 bars????
of a what? 150 psi is a pressure ...it's like saying what is the average weight in kg's of a blue / greenQuote:
You seem stumped...
You've supplied a pressure rating without saying what the pressure rating applies to.
Anything pneumatic can be given a pressure rating
A valve @ 150 psi / 10 bar ( This pressure is the industry norm )
A Fire extinguisher might be rated @ 1000 psi / 68 bar etc...
For information on the weight / mass of the item you must be a little more specific.
E.G. The weight / mass of a 1/4 5 port valve.
The weight / mass of a 100mm bore 200mm stroke cylinder.
Even then it's a very open ended question.
Pic of a selection of regulators ranging from 2.5kg's down to 200g ...the smallest ones are not suitable for you they only output ( unless modified ) a low pressure
[attachment=0:2esa8y9s]P1010016c.jpg[/attachment:2esa8y9s]
any idea where to get one ? apart from trev cos hes nt replied
RIGHT:
Whatis the average weight of a 150psi/10 (and a bit) bars pneumatic system of a featherweight?
Theo
i tried aswell but no repliy :angry: :( :cry:Quote:
Originally Posted by jonophilpott
Theo
No
I've always made do with what I have kicking around.
What is the average weight of a 150psi/10 (and a bit) bars pneumatic system of a featherweight?
Good grief!.....Um
0.6kg co2 bottle full weight ...1kg ish
Regulator 0.5 - 0.75 kg
Valve ( complete ) + fittings + tube 0.5 kg ish
Pneumatic cylinder 0.5 - 1.5 kg's depends very much on construction and size.
relief valves plus bits and bobs 0.5 kg...
Plus a buffer tank if your going to use one
GUESSTIMATES ONLY
To the optimist, the glass is half full. To the pessimist, the glass is half empty....To the Robot builder there is just too much glass.
can anyone suggest a suitable buffer tank please?
I hear that a fire co2 bottle will do
Theo
