Ok sure, here are some photos. The circuit as a whole, the individual bits and then the link.
Attachment 5961Attachment 5962Attachment 5963Attachment 5965Attachment 5966Attachment 5967Attachment 5968Attachment 5969
Attachment 5970Attachment 5971
Also one of the motors has been making a grinding/crunchy sort of noise when I turn the axle by hand. It also moves a bit less freely, and didn't want to lock up with grub screws as well as the others. Could that be a problem related to this issue? It's still attached to a bulkhead here because I can't get it out without a thinner pair of pliers to grip the axle with.
Thanks.
EDIT 08/03/18: For those reading this in the future, turns out that wiring the fuse on the positive side of the battery, is a more correct way of doing this. So the order should be on the positive side: Battery terminal - link - fuse -*split to parallel*- Led, OR Esc - Motor.
