If you dont mind having huge gashes in them from spinners, you could.
i think 3.2 hardox is as good as anything available. you dont need it any thicker and placed in the right places instead of all over the robot you would save loads of weight. rubber mounted ali on top for hammers and axes and hardox outer shell would be very good. you will be surprised what you can do if your robot isnt all 10mm ti and 10mm hardox.
http://strickenone.proboards99.com/index.cgi?board=teamww&action=display&thread=268http://strickenone.proboards99.com/i...isplay&thread= 268
Mighta been delirious while designing this one, and therell be MORE setups soon
I agree, although 3.2mm Hardox 450 will not keep everything out (Tiberius comes to mind).
Steve had something called Chameleon once, if I recall...and if the tyres are covered, how can some setups be invertible? For that matter, how can tracks have tyres? :P
If Steve did have chameleon Ill rename it, and what I mean is there are removal armour panels over the wheels
But you said it had tracks...
Sorry, having a slow day today, I meant tracks
Interceptor: http://strickenone.proboards99.com/index.cgi?board=chevhw&action=display&thread=158&p age=1http://strickenone.proboards99.com/i...isplay&thread= 158&page=1
This is not so much an is it in weight/realistic post as it is how could I make it more effective since Ive looked at it and it...doesnt look that good, to be honest.
So, how could I make it more effective? :proud:
Blood Eagle
Weight: 100kg
Shape: A very low wedge with side skirts
Dimensions: 94cm X 75cm X 42cm with the beak closed, and 94 X 75 X 60 if raised
Armour: 7mm Titanium
Power: 2 X 24V S28-400s powered by 4 24V NiCad BattlePacks
Wheels: 2 X vulkalon rubber tyres
Top Speed: 19 mph
Ground Clearence: 0mm on the front and sides due to Firestorm-like blade and side skirts and 2.1mm on the back
Turning Circle: Yup, its zero.
Weapons: A very nasty, diamond edged crushing beak (ala Razer) powered by a Vivoil Hydraulic Pump, with 3800PSI of force. There is also several Mute-style barbs to trap other robots while crushing them.
Srimech: Razer-Style Arms on sides powered by steel cables and rounded back to stop it from getting beached.
Strengths: Extremely Fast Srimech, Devastating and Lethal Weapon, Almost Impossible to get underneath, Good Traction
Weaknesses: None- Almost Invincible
OK, so.... is there anything wrong with THIS?
