I knew that, its just I couldnt see such an idea being effective without real weight in the ends.
How much weight would you recommend? Baring in mind that it cant have too much, otherwise it wont lift up.
If its equal on both ends, it should lift up rather nicely...I think those motors will be more than enough to ensure it lifts up, so Id pad it up to the 13.6kg limit, so...1.8 extra kg per end?
Hey Chris, You made a thwack bot ? Is it anything like my Antweight, FIN ? Look him up on youtube, or on my website
I like Thwackbots :)
Wrangulator is perfectly feasible, in fact there are many reallife feathers with about the same specs (Bonx and Batterbot for example). Even with 4mm of hardox they have plenty weight left.
On the others I would need more stats on the weapon just like Joey says. What bottle, what ram what mechanism and so forth.
I will be at the UK champs this weekend so I wont be able to read the forum till im back in Belgium or Holland.
Say...
Is it possible to have a lightweight (25kg) with 3.25mm Hardox armour and LEM130 drive? :)
yes
Okey dokey then.
*goes to drawing board to make a new clusterbot* :)
In the past week Ive made about 6 vapours!!
Is there anything wrong with this one?
http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=229&p age=1http://strickenone.proboards99.com/i...teamww&thread= 229&page=1
Is the self righter part of a section that doesnt spin? I cant really see how itd work otherwise...
Incidentally, if you got it to spin fast enough you could get it to appear white :P
