looking good AJ
looking good AJ
Looking awesome AJ :) Looks very professional! Keep up the good work mate.
It is looking rather cool.
Also off topic but gonna say it - was looking at peoples profiles - Kenny your heavy weight is looking cool dude! And Aaron, that picture of your nicads like that scares me. LOL. Just waiting for someone to touch the wires together :proud:
Mr Stu
Lol, that was a long time ago, I dont build shrink wrap packs any more, dont like how weak they are, check out my profile now with one of my intercooled poly packs. I can now throw my battery packs at the brick walls on my house with no problems :proud:
New carrot feather is a 4 motor drive too... just welded the gearbox cages onto the chassis.. see profile..
Is that the planetary ring gear youve welded to the chassis????
yep
planetary gear cages welded, drive shaft bushed through 50x25 2mm ERW chassis, no more of that floppy motor mounting business with jubilee clips..
cant remember if i posted this before or not but hey ill do it anyway lol
Drive: 2x 18v dewalts with the complete team delta setup at 24v, 2x 3 x 1.5 colsons and home made bearing blocks
Weapon: as if it needs one :p
Battery: 24v CP2400scr nicad packs
Speed controller: victor 885
Armor: 6mm mild steel angled all over, base lid and wedge are 3mm, the inside pieces are all 4.5mm stainless as are the wedge mounts.
Status: just about ready
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02428.jpghttp://img.photobucket.com/albums/v3...s/DSC02428.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02437.jpghttp://img.photobucket.com/albums/v3...s/DSC02437.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02439.jpghttp://img.photobucket.com/albums/v3...s/DSC02439.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02460.jpghttp://img.photobucket.com/albums/v3...s/DSC02460.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02462.jpghttp://img.photobucket.com/albums/v3...s/DSC02462.jpg
Drive: 2x 9.6v drills at 12v with dual 95mm wheels
Weapon: 115kg crusher
Batteries: 12v cp2400scr pack
Speed controllers: umm basically just some lego IR controllers that fire off relays... its an interesting setup ill tell you that :p
Armour: 12mm MDF held together with 3mm ali L bracket and m6 bolts. the crusher is all 4.5mm stainless.
Status: just needs final wiring and drives mounted.
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02262.jpghttp://img.photobucket.com/albums/v3...a/DSC02262.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02421.jpghttp://img.photobucket.com/albums/v3...a/DSC02421.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02422.jpghttp://img.photobucket.com/albums/v3...a/DSC02422.jpg
http://glen.botclips.net/Woodzilla test%202.wmvhttp://glen.botclips.net/Woodzilla test%202.wmv
Drive: 18v drills at 24v, 95mm custom polyurethane wheels. these gearboxes are hand modified by a good friend to have bigger pins and theres 6 on the output and supported on both sides, BULLET PROOF.
Weapon: 260mm saw blade. 850g in weight driven staight off a giant fan motor that has a spinning plate. ~ 4000rpm
Batteries: 24v 3000mah nimh pack
Speed controller: IBC
armour: 10mm 5083 ali everywhere 12mm wall thickness pipes on the sides
notes: came second at our last event, woohoo
http://img.photobucket.com/albums/v357/Cobrarobotics/Kang/DSC02471.jpghttp://img.photobucket.com/albums/v3...g/DSC02471.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Kang/DSC02010.jpghttp://img.photobucket.com/albums/v3...g/DSC02010.jpg
http://glen.botclips.net/Kang%20vs%20BoB.wmvhttp://glen.botclips.net/Kang%20vs%20BoB.wmv
http://glen.botclips.net/Plan%20F%20vs%20Kang%20vs%20Retread.wmvhttp://glen.botclips.net/Plan%20F%20...%20Retread.wmv
/end
(Message edited by Glen on December 08, 2005)
Just finished uping the power on Kishar from 12v to 24v for the Disc. Small vid on http://www.teamdragon.org.ukwww.teamdragon.org.uk bottom of Kishar page
Hmm. Very Nice Tony.
That reminds me why im in no hurry to get my feather finished any time soon!!
Finally made a page about my neat new HTI gearboxes :)
http://www.micro-maul.co.uk/gearmod.htmlhttp://www.micro-maul.co.uk/gearmod.html
I now have the ability of running at up to 24v with less risk of burning out the motor
Having seen HellBringerX run 4 x HTI motors with SS2 gearboxes @ 24v, Id say you have the same chance of blowing the motors up as a Mini EV :proud: HellBringerX smoked on average 2 motors per event, IIRC.
I have seen quite a few reports on the american forums of the HTIs burning out at 24v in various configurations/set-ups but im sure you will have much better luck at 18v.
Chris - ^_^
sorry, what did you do here?
swapped some cheapo drill motors for slightly more expenseive cheapo drill motors?
no offense meant, just a lot of writing about a simple thing.
I have been running 2 wheel drive 600 size 6volt motors at 24 volts for 6 months now, no big deal really, pushed pillow torque in a couple of fights... and ran well on plastic gears for 3 events.
I personally would use better motors on the gearbox you have, but thaTS JUST ME.
Actually I thought Ewans effort was something to be commended rather than taken to bits. Clearly a lot of thought went into produce an information page with no use other than trying to show others how they can work on their machines (which is pretty self-less if you ask me).
Yes you might choose a different motor - but doesnt the fact that someone Ewans age can do the job of modifying the gearbox, and have the nouse to document it and write about it deserve support rather than a flaming ?
Seriously Ewan, dont let them get you down !
Ed
fair point, although i think the actual mod was simple, and a bit pointless documenting it, I must say that Ewan has done something I find extremely difficult.
Putting this information on the net is not a thing i find easy, so yes, all commendation to Ewan on that, and to the fact he is selfless in his attempts to help everyone for no reward other than the enjoyment of helping. Fair play.
Doesnt change the fact that I worry about people Ewans age (and sometimes a little older) posting indepth information that I often feel is misleading, inaccurate and to be honest, does more harm than good, but in this case, yes, very well done article, not all acurate, but still... changing motors is not rocket science. I would be far more interested in why Ewan chose this motor? What benefits are there? What are its specs? It says basically, but more info would be nice, since so much time and effort was put in. Also, more info on the gearbox, what can it do at its limit?
People who visit this forum for information benefit a lot from people like Ewan, who put so much stuff up for them, but I have to say that there are times when I cringe at the stuff being said. I wonder how many people copy bad advice and give up when it doesnt work? Very few people realize how old some of our experts are, which I feel is dangerous.
This is nothing personal against Ewan, or anyone else, heck, Im sure people would disagree with some of the advice I give, but I always try to be sure that I am giving the best advice, not the latest thing i tried and dont know if it works yet. I have come accross a lot of people who have said that half the stuff you read about building robots is bad advice... I agree
Ewan has achieved something else I cant, Ed jumped to his defence very quickly, so he clearly knows how to make friends and influence people :) A future world leader maybe? :)
and having said that.....
Ewan DID put info links about both motor and gearbox....
slinks away under a rock, with egg on face....
you do that
Just a suggestion... maybe the FRA should put together a set of guides like these to help beginner roboteers? I beleive the Aussies are doing something like this at the moment.
It looks like Ewans guide was written just in time are the SS2 gearbox and the HTI motor is no longer availible on The RMP or RDS , Great Going Ewan !
A little correction required there, the HTI motor is still currently available. Its a decent motor, though due to its size, as said by a couple of people above, running at 24V is pushing it. I intend to run with 75mm wheels - smaller than wheels used by most, and as Ive got a spare pair of motors Ill try running at 24v, see how it goes, and if neccessary go down to 18v.
I will correct myself , the HTI motor with the pinion gear is no longer availible at RMP
http://www.robotcombat.com/marketplace_ss2.htmlhttp://www.robotcombat.com/marketplace_ss2.html
out of interest, would anyone be interested in buying some of these?
if so, they are £120 (included postage and import duty) per pair as sold by robotpower.com with motors.
e-mail me if interested.
AJ The old Battlebots site has a bunch of such guides... http://forums.delphiforums.com/BattleBot_Tech/starthttp://forums.delphiforums.com/BattleBot_Tech/start :
The Ultimate Guide to Radios
The Ultimate guide: Antweights
The Ultimate guide to DC motors
Ultimate Guide to Drill Motors
The Ultimate Guide to: Batteries
The Ultimate Guide to Materials
The Ultimate Guide to: Speed Controllers
Ultimate Guide to Tapping Holes
Guide to Delphi Forum Usage
Ultimate guide to Soldering
Ultimate guide to Pneumatics
Ultimate Guide to Linear Actuators
Ultimate Guide: Internal Combustion (IC)
The Ultimate Guide: Hydraulics
Ultimate Guide to pit behavior
Ultimate Guide to: Armor
Ultimate Guide : Solenoids & Contactors
Ultimate Guide To: Kevlar
Ultimate Guide to: the Ultimate Guides
The Ultimate Guide to: Sponsorships
The Ultimate Guide to EV Warriors
IFI Robotics - Victor 833 ESC
The Ultimate Guide to Tracked Bots
The Ultimate Guide to: Gear Reductions
Ultimate Guide to Kinetic Energy Weapons
The Ultimate Guide To Being Under Weight
The Ultimate Guide to PICs and PLCs
though the forum itself has slowly died back from its former glory.. (I wondered where all the yankee builders had gone, at one point, but they seem to all be safe on the RFL forum)...
http://www.robowars.org/wikka/RobowarsWikka1http://www.robowars.org/wikka/RobowarsWikka1
Thats our RoboWars Wiki we are all chipping in to work on here in Oz. Not a huge amount there currently, but it is getting mor and more added each day.
And same in finnish :)
http://bertling.fi/robowikihttp://bertling.fi/robowiki
Rebuilding started on Tiamat. Latest pic on profile.
Are you sure you havent copied and pasted a picture of little flipper? ;)
Very nice, looks a good layout
No Im sure I havent as both the drive motors are at the back. The flipper is made out of 4mm Hardox. The side armour will be made out of 20mm nylon. Haveing a manifold made at work from 1in thick Ali. Ram from Mario.
Looking at the tap youve got on the tank Tony, are they available as a seperate part or did it come that way? I could do with something like that for my paintball tanks. Also, what are those wheels? Im gradually getting a proper parts list together for a featherweight Savage Toaster. Coincidently I was looking at a big slab of Nylon 6 at school (work) the other day. Weve got a little Roland CNC milling machine that could make quite decent Toaster sides out of that and pocket out the back to save weight too...
No they came that way. Got the tank of Jonno. I got the wheels from B&Q give plenty of grip. We have used the nylon before and Little Spinner could not get through it.
Cheers Tony. Wheels from B&Q eh? What are they normally used for?
Dont know they were just selling them seperatly.
Hmmm... Trip to B&Q tomorrow then... Either that or its off to the car boot sales for ab rollers
Drive: 4x 12v drillmotors
Weapon: pusher
Battery: 4x 12v
Speed controller: H-bridge
Armor: ??
Status: just about ready, just need some armor
can get a picture on my profile tomorrow:)
Latest pic of hornet on profile.
Drive - 2 12v golds (upgraded from 12v wiper motors)
Weapon - 2kg spinning disc (hardox)
battery - 2 x 6v 3000mAh nicads (upgraded from 12v 2.1Ah SLAs)
speedos - 2 electronize
armour - 4mm hardox
status -
Have decided to beef up the drive train and weapon supports with 5mm thick ali. Still got a fair bit of work to do on the disc at the back. Will soon be moving *crosses fingers*
Looks very heavy Gary, how much does it weigh?
Mr Stu
Hornet is looking very cool ,I cant wait to fight that thing .
Looking very good Gary. When do you think we will see it in a event.
Got the 3 HTIs mounted in Kishar for the weapon drive. Will see how it works at Magna. Pic on profile.
