Re: crazy bots series 1 (the remake)
lian: ok welcome back and we have a pit reporter heres max green with the bots
max: hello there kody wanna know who your up against
kody: yeah sure
max: your up against mute
kody: piece of cake, i will just tear it apart
max: but he has a flipper and you have no scrimech
kody: does this face look bothered? dont think itll last 1 second
max: good luck
kody: ta mate
max: so adam emmett want to know who your up against
adam: hope its not a spinner
max: unfortunatly, its raven the 4th
adam: oh dear
max: what are your tactics
adam: try and reverse and use the rear flipper to lift him up then turn around and use the main flipper
max: good luck
adam: were gonna need it
pod 1: raven/kody
pod 2: mute
raven spins up to max speed already as mute turns around to use the rear flipper as adam said and mute comes in slowly
and gets closer and closer and closer and BANG mute is sent spinning like crazy across the arena but mute comes back only to be whacked away again but mute comes in and flips and OH MY WORD the flip made ravens blade hit the floor
and shot 7ft into the air and landed back on its wheels at full speed and now charges at mute who turns away just in time
now raven hits again and sparks fly and mute is flung across the arena but still comes back for more, mute has to be the
bravest bot in history to go after raven like this and comes in again only to be whacked away once more in the pods
adam emmett looks on with tension as kody is looking on with delight whislt listening to mastadon through headphones
now mute bravely comes in reverse and hits raven and is spun away again but comes back in reverse yet again and is
wacked hard that the rear flipper has broke off, but mute isnt moving but still has weaponry, boom another hit from
raven has spun mute across the arena and into the pit release down goes the pit as the countdown begins well done
raven 1 2 3 4 5 6 7 8 9 10 here comes the house robots but raven spares mute by pushing him down the pit
CEASE
the heat final is kody vs mark
Raven the 4th vs. Mega Roll 2
Destroy it. :P
raven vs megaroll: i see a demolishon here, one way or the other, but il say kody will edge this one
brutalis is bouncing across the floor but is stable now and comes in with a flip and down comes drumroll with a crash
Wow, I'm fighting in a battle I didn't even enter into - awesome :P
Damn Brutalis for flipping me, my self-righting hoops don't work too well :(
lmfao I didn't even see that. XD
I'm just that sad :crazy:
Raven the 4th vs Megaroll II: I'm going to try and get to him before he spins up. If he spins up too quickly, press the pit release button and play cat & mouse around the pit. If the opportunity comes, drive at Raven in such a way that she will hit me, ricochet off the wall, and land in the pit. If that doesn't happen, then keep hitting her with the drum. With a spinner like that, something's going to break if it hits something.
Yep. Your robot will be the one to break. 'Cause I've got shock mountings. :proud:
Oh yeah, and I'll make sure to stay away from the pit. I don't want any fluke victories happening. :P
You'll have to come near the pit to attack me... :P
Then I'll chase you around the edges of the pit that are nearer to the arena centre, therefore winning a JD on aggression. :proud:
I can do this all day, Mark. :P
