or what about construction entirely from polycarb?
You have 3 choices here:
A monocoque? (spelling please):
Literally meaning 1 shell in old french. Basically the posh term to mounting everything to the armour and base panels. Used often in feathers to improve armour.
A chassis. A frame and supporting structure used to hold everything to and to hold the armour in place. Weightly but has slightly more reliability.
or
a combination of the above.
If youre thinking of using polycarbonate for a shell, I recommend metal panels over the edges. you only have to see terrorhurtzs S5 battle for an answer...
Oh and Woody: Why would he post a heavyweight construction in the featherweight section???
ok peeps id like to get started now on my robot. Im thinking of buying some 6mm polycarb then plating that with metal sheets. How do i work with polycarb i.e. hold it together? I might upgrade to a box steel chassis when i get the funding. I know ewans had some success with this so i was wondering if he could help
If anything mark i would have thought that a steel box chassis would have been cheaper than polycarbonate unless you are getting the poly cheap. nuts and bolts are probably the best way to hold it together.
mark, see http://www.micro-maul.co.uk/micro-maul%281%29.htmlhttp://www.micro-maul.co.uk/micro-maul%281%29.html
you can use thick polycarbonate sheets (of 10mm +) to make a chassis. You just have to tap it together. Dont have any exposed polcarbonate edges though as they will get caught on by a spinner and can shatter.
ok thanks all. I can get upto 6mm polycarbonate cheap but i suppose thats not enough. Anyone know any suppliers apart from plastics plus
Technobots sell loads of polycarb.
I bought a few various panels from Rob Jones. They were various lengths and widths, averaging 400*400 (mm).
http://www.robotstuff.freehomepage.com/catalog.html>http://www.robotstuff.freehomepage.com/catalog.html
Other than that, I could only recommend Technobots. Usual URL.
is the 6mm stuff thick enough?
oh yeah if in doubt double it up and make 12mm
