Re: Pulverizer Build Diary
Should i use gears and chains or pulleys and belts for gearing down the motors?
In other news, this is my antweight, mini pizza. The base is alluminium, the outer ring is a steel cookie cutter, and the motor is from a handheld vacuum cleaner that i could take apart (i think....). So far it weighs 98 grams so the lid will be cardboard. The outer ring is 3 inches in diameter so it should fit in the size limit nicely.http://i1280.photobucket.com/albums/...ps58e823c3.jpghttp://i1280.photobucket.com/albums/...ps6d3434f6.jpg
That is the SMALLEST antweight ive ever seen!
They can be about 5 inches long it just has to fit into a 4 inch cube.
Looks quite cool but good luck getting anything else in there.
Should i use gears and chains or timing belts and pulleys for gearing down my featherweight?
