Re: Featherweight Database
Originally Posted by Leonardomayo
I've found that, I've bought 2 and one had plastic gears and one had metal gears
Just swap one set of plastic gears with a set of metal gears and you'll have two motors each with a combination of metal and plastic gears, thus balancing them out rather than having one stronger and one weaker drive motor. Standard drills tend to come like this anyway; the metal stage is the one closest to the output shaft, and the plastic stage engages with the motor pinion.
Where would I get said gears? I'm quite tempted just to buy 4 from robochallenge to cut out the hassle.
From your existing drills. If you've got one with metal gears and one with plastic gears, that's six individual metal and six individual plastic gears you have. A standard drill gearbox needs six to run so use three plastic and three metal gears in one drill gearbox and use the remaining ones in the other drill gearbox. Voila :)
I like your thinking, i'll butcher them further tommorow.
Power: x2 9.6v 3300 mAh nimh batteries
Drive: 12V argos drill motors on 10cm blue wheels.
Weapon: a set of linear actuator driven claws with that also running off the 2 9.6V batteries
Control: Electronize 15a esc's with 25a fuses
Armour: 8-10mm HDPE top and base & 5mm checkered steel sides
