Side roll because theres a backbone on the design, the panel can sit against when bringing it back
Name: L.A.S.E.R (pretty random)
Power: 12v 3300mAh Ni-Mh
Drive: Cheap 12v drill motors
Control: Sabertooth 2x25A
Weapon: lifter
Armour: 2mm Steel(front), 15mm HDPE (chasis), 6mm HDPE (top and bottom)
R.C: PLanet T5
Cost: £200
May as well join in:
Power: 2 * 6V 3.3ah SLA/custom 12V 4.4ah NiMH battery.
Drive: 16.8V drill motors on 10cm blue wheels.
Weapon: Custom thread rod actuator powered by a 9.6V drill motor.
Control: IBC & Syren 25A
Armour: 12mm HDPE & 10mm polypro with 3mm Aluminium panelling.
Notes: Fought valiantly in the 2010 champs but succumb to technical difficulties. Met little spinner 2 4 times in 7 battles. 3mm aluminium bent & polypro broke within 3 fights.
Sounds like the guy who built it did a shoddy job :uhoh:Quote:
Originally Posted by psychostorm
Power: 12v 4300mah
Drive: 4x 12v argos drill motors on 10cm blue wheels. Kenny made the motor mounts for me.
Weapon: two spikes! (first bot so thought id go simple!) and can run either way up
Control: Spektrum dx6i with 4 little blue ESCs
Armour: 20mm HDPE chassis with 5mm aluminium lids
After I bought it, I even found it was cut & shunt from another machine. :proud:Quote:
Originally Posted by k_c_r
Does it run well? I'm thinking of a similar drive setup for my first robotQuote:
Originally Posted by Danjr1
yeah, runs fine! the dx6i mixer needs a little setting up but i can post the link if needed. only small issue is that the argos motors can be a little hit or miss with regards to quality but then again for £10, u cant moan!
I've found that, I've bought 2 and one had plastic gears and one had metal gears. But for £10 not bad.Quote:
Didn't even though that about the gears?! Will have to check mine outQuote:
Originally Posted by Leonardomayo
