I think you maybe reading the wrong stats, Hatchet: Evo has no scoop
That would be mine. :P
But if it displeases you, I will change that Generic skin, since theres no way in hell you would join for the hell of it. :P
EDIT: Generic skin has been modified.
(Message edited by kodster on May 18, 2008)
In all honesty, its easier to read it now I changed to black on white :P
feel free to use the VaryingEveryDay Skin people :proud:
Henry IX
http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=189&p age=1http://strickenone.proboards99.com/i...teamww&thread= 189&page=1
Cant really see how you can run an axe off a rack and pinion from an electric motor...otherwise good.
quote:
One problem: B42s dont really exist. :-O
Aaron brought in a farfetched idea about B42-500 MagMotors a few years ago and generally everybody accepted that they were real...until people did some researching and found out they didnt exist. The closest thing to those are BFA42s, but theyre not as powerful as LEM200s.
The B42 series of Magmotors did in fact exist, they use to be branded under the name of Bxx-yyy (xx replaced with the model number 42 in this case, then yyy winding rating, 500 in this case). They changed the branding of the motors over the last few years. Research would have lead you to http://web.archive.org/web/200308271...m/B42.htmhere.
What do you think about my new bots?:
Roveress Evo
Weight: 100kg
Shape: Biohazard, with Growlers head at the front.
Colour: Brown, with black and white splotches in some places.
Dimensions: 95cm x 65cm x 30cm
Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 foam filled wheels.
Armour: 6.5mm Titanium/Vanadium alloy.
Speed: 21mph
Ground Clearance: 0mm at front due to wedge, and at sides and back due to skirts. 5mm at sides and back without skirts.
Turning Circle: 0m
Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge with Mute-style barbs on it. Once a robot is stuck on the wedge, the top Jaw, powered by a 2.1kg 1000psi Nitrogen tank, comes down with over 5.5 tonnes of force.
Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
Side Swipe 2
Weight: 100kg
Shape: Panic Attack (S2) with a Tornado style wedge on the front
Colour: Silver
Dimensions: 90cm x 65cm x 35cm
Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, at back and sides due to skirts. 5mm at back and sides without skirts.
Turning Circle: 0m
Weapon: A titanium 5kg 70cm-in-length spinning bar that spins at 2000rpm, powered by an S28-400 Magmotor.
Srimech: Invertible
And... My brand New Vapour!!
El Camino
Weight: 100kg
Shape: Round Dome
Colour: Red. The teeth are painted gold.
Dimensions: 80cm x 80cm x 25cm
Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 2 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
Armour: 5.2mm Hardox
Speed: 18mph
Ground Clearance: 0mm all around due to circular skirt. 5mm without skirts.
Turning Circle: 0m
Weapon: The body spins around at 2000rpm, powered by an E-Tek, and has 4 Hardox teeth approximatly 6cm above the ground.
Srimech: Invertible
Feel free to help me get my bots (possibly) ready for Robot SMASH!! Series 2.
ROFL :rofl:
Didnt Liam ban you completely from his tournaments? I guess you must have dropped your contact lens, because you cant read.
Get out.
OK, so I thank everyone for helping me with my heavyweights. Now, I need a little bit of help with my other-weight robots.
Wrangulator (FW)
Weight: 10 kilos
Body Shape: Diamond Shaped, a bit like Eye Of Newt from the Series 3 pinball tournament.
Speed: 20mph
TC: 0
GC: 0 under each wedge, 4mm otherwise.
Wheels: 2 inner.
Power: It has similar to what powers Rip.
Armour: 2mm aluminium
Colour: Dark Grey.
Weapons: A wedge at each end, tipped with a miniture blade. Because of the way the wheels are positioned, the robot can tip from one wedge to the other. The robot also has spikes on the side of these wedges. To use these, it spins on the spot, lifting both wedges off the ground and lifting the spikes in the air.
Srimech: Invertable.
Strengths: Fairly powerful.
Weaknesses: Armour.
Little Big Bot (LW)
Weight: 22 kilos
Body Shape: Looks a bit like Biohazard, without the skirts.
Speed: 15mph
TC: 0
GC: 2mm.
Wheels: 4 inner.
Power: 2 12v batteries, plus couple Magmotors... the usual.
Armour: 3mm titanium
Colour: Yellow top, Green sides, Red LBB letters on each side.
Weapons: Nasty axe with Dominator 2 style point.
Srimech: Uses the axe for that.
Strengths: Weapon.
Weaknesses: Lack of experience.
Tom (MW)
Weight: 50 kilos.
Body Shape: Basic wedge.
Speed: 14mph
TC: 0
GC: 0 at wedge, 3mm otherwise.
Wheels: 2 inner.
Power: 3x 12v batteries, plus Magmotors.
Armour: 5mm titanium.
Colour: Painted after the cartoon cat after whom it is named. You work it out.
Weapons: Front flipper, which can throw five times the robots weight into the air.
Srimech: The flipper does that. It also has whiskers and a tail to prevent side and back strandings.
Strengths: Weapon.
Weaknesses: Jerry!
Octo-Push 3 (SHW)
Weight: 150 kilos
Body Shape: Box Wedge shape, basically. A bit like Minion, I guess.
Speed: 10mph
TC: 0
GC: 0 at front, 3mm around sides, 2mm where disc is.
Wheels: 6 semi-outer (protected).
Power: Same stuff Storm 2 uses.
Armour: 3mm Steel.
Colour: Aqua green, light blue and light green wheel protectors. The spinning drum has a light blue top and dark blue sides. Two yellow Octopus eyes are attached by springs to the robot.
Weapons: Front wedge and massive rear Drum, spinning at 1000 RPM. Think of it as Storm 2 meets Revolutionist meets Squidward Tentacles.
Srimech: ....you know, Im not even going to bother. Something that large would need a miracle to overturn, BOTH ways.
Strengths: Power, weapon.
Weaknesses: No srimech.
To be completely honest, Im thinking of giving Octo-Push a complete overhaul.
Either way, some advice from anyone would be greatly appriciated. If your name is AJ, Steven or Joey, then that would be especially nice, because all three of you have given me great guidance in the past. If your name is Mark Elam, then iss-pay ff-oay!
