I just pulled the power plug in and out off the Receiver, and the motors work for 1 second It seems like the power is not going to the receiver.
Well I got my right side motor working but my left is not. I change the receiver to the Etronix pulse without the mixer.
all of what your saying sounds like problems ive had before with the same set up, problem is its been over half a year since ive touched the robot so i litterally cnt remember how i solved all the problems i had lol, but the flashing yellow light problem used to happen to mine when i used the robots weapon as the voltage spike would crash/reset the speedos/reciever, cant remember which lol you can buy or make a capacitor that plugs into your reciever which might solve your problem, as that helped with mine before
Update
Good news I got Mr Pink working, the problem was one of the booster cables was plugged the wrong way :oops:
So I missed Kidderminster but I still have Maidstone in November too go to.
At the mean time here's a picture.
[attachment=0:2ou456ee]Mr Pink A01.jpg[/attachment:2ou456ee]
why don't you go today?
I don't think I can get the armour on today because my drill bit's well wear out and there not good quality.
I can try and see.
Looks like it will be solid as a rock with that armour in place.
How thick are the sides? They look like at least 8mm :shock:
There 4mm and I don't have enough hardox for the top so I'll have to use Aluminium Plate.
[quote=JammyONE]Update
[attachment=0:1i7vfa28]Mr Pink A01.jpg[/attachment:1i7vfa28][/quote
Whats the dimensions of this bot
