FRFFT: Series Two: Redone!
Were pretty even opponents for this middleweight match, but I have the weaponry advantage. My best hope is to try and stack ROID against the wall, or gain pushing advantage my removing its traction before pushing it across the arena. If I cant pit or stack it just be dominant and try to win a JD
Good luck AJ :)
Welcome back! Last time, Drive was flipped out by Toro.
Next, two middleweight robots: ROID and Hyper-Ventilate
From England, Hyper-Ventilate!
Lewis has entered this robot. It is basically two wedges joined in the middle by a pipe, to which is attached a spiked arm that can ram and lift other robots. But the wheels are exposed.
From England, ROID!
AJ entered this wedge shaped robot. Its main weapon is to push other robots around. Its invertible, but how effective is it?
Roboteers, stand by!
3-2-1: Activate!
ROID doesnt seem to be worried about that weapon of Hyper-Ventilate because it CHARGES Lewiss robot and pushes it onto the flame pit. The lifting arm of Hyper-Ventilate smashes onto the top of ROID, but no damage. Hyper-Ventilate backs off the wedge and continues to swing away with the arm! AJ isnt fazed and tries to push Hyper-Ventilate again, but Hyper-Ventilate gets under this time and pushes ROID into the CPZ. It lets it go, but hits it with the arm a few times. ROID turns to face Hyper-Ventilate again and gets under! Pushing Lewiss robot against the angle grinder! Not much effectiveness with these two, but ROID is the more aggressive at the moment. The Hyper-Ventilate weapon strikes the top of ROID, making a few dents, but nothing else. It breaks free and hits ROID again. Now it goes over to the pit release and OH! It gets rammed into the button by ROID! Almost knocked over, Hyper-Ventilate! The pit goes down, and Hyper-Ventilate whacks away with the arm again. ROID pushes it into the CPZ! Hyper-Ventilate gives chase and swings its arm madly at ROID! ROID turns again, but Hyper-Ventilate gets under the side of ROID this time and pins ROID with the arm! ROID tries to drag Hyper-Ventilate around, but Lewis is in control and pushes ROID onto the flame pit. The armour on ROID is quite strong, so no damage there. It lets ROID go, and AJ tries to push from the side. Hyper-Ventilate swings the arm onto the top again, but still no damage! OH! ROID drove into the CPZ, and Hyper-Ventilate has it cornered! Bashing away with the arm, AJ is pushing back! Back...towards the pit, maybe?! No! Hyper-Ventilate backs off the wedge and escapes to the centre of the arena. ROID charges at it, but it rides up Hyper-Ventilates wedge and gets lifted up by the arm! Now ROID is in trouble! Being pushed around by Hyper-Ventilate. The last ten seconds of the clock count down. ROID is dropped onto the flame pit, bu it gets behind Hyper-Ventilate and pushes it towards the pit! OHH! Hyper-Ventilate almost in, but it survives to go to the judges!
Cease!
What a fight! The judges will have to decide!
Hyper-Ventilate: S: 3 C: 3 D: 2 A: 3 Total: 11
ROID: S: 2 C: 3 D: 1 A: 3 Total: 9
Hyper-Ventilate is the winner! Well done to Lewis!
So, the middleweight Round Two lineup:
Hyper-Ventilate/Complete Control/Typhoon/Blizzard
That looks like a good lineup!
Next:
Achillies VS Maleficant
OverDrive VS Micrompression
From Wales, Maleficant!
An invertible box with a scoop on the front backed up by a spinning disc! Daniel entered this robot, which hasnt fought before. Hopefully the destructive weapon should make up for it. For this fight, Daniel will be keeping the disc!
From England, Achilles!
Alex entered this heavyweight robot. It has a flipper that can be powered by two setups: hydraulics and Co2! For this fight, Alex will be using the Co2 setup. It can self-right using a seperate self-righting mechanism, but how effective will the flipper be?
3-2-1: Activate!
Maleficant charges towards Achilles, but Alex veers to the side and FLIPS! He missed, and that allows Maleficant to RAM into the side of Achilles. Sparks fly from the disc! Achilles turns and this time DOES get the flipper under. Over goes Maleficant! It cant use the disc properly now! It tries to push Achilles from the side, but Achilles gets under the inverted scoop and FLIPS it over again! Now Maleficant is back the right away up and SMASHES into the side of Achilles with the disc, and Achilles almost flipped over by the power of the disc! It gets away, but Maleficant clips it on the back! Achilles turns to face Daniels robot and tries to get under the front, but Maleficant gets under the first and OH! Achilles spun onto its top! It self-rights, but gets SMASHED into by Maleficant! Achilles over the flame pit, a few scratches and dents, but nothing more. Achilles turns and gets under the Welsh robot, THROWING it over! Maleficant hides behind the Refbot, but Achilles follows and FLIPS it up, but not back the right way! Maleficant crashes back down, but Achilles pushes it towards the wall! OH! Not out, but almost! Maleficant comes back down onto the arena floor, the right way up and CRASHES into the front of Achilles. Achilles flips itself away, but allows the disc to get at its underside. It turns and flips Maleficant once again, and AGAIN! Maleficant charges in and sparks fly! Achilles pushed towards the angle grinder, but it gets away! Alex turns to push Maleficant from the side, but it turns and SMACKS Achilles with the disc! Achilles FLIPS, but misses again! OHH! The disc of Maleficant flips it over again! Achilles self-rights, but Maleficant crashes into the underbelly again with its disc. A good battle here. Both robots were on top at one time or another. The last ten seconds count down! I think theres a slight gash on Achilles. It FLIPS Maleficant again. Maleficant tries to push from the front, but Achilles gets under the wedge and THROWS it the right way up again!
Cease!
The judges will have to decide. Achilles finished stronger there!
Achilles: S: 3 C: 3 D: 1 A: 3 Total: 10
Maleficant: S: 3 C: 3 D: 2 A: 3 Total: 11
Achilles has found its weakness!
Maleficant goes into the next round!
And after the break, the last qualifying battle of the series: OverDrive vs Micrompression!
See you then. Hope you liked the fight
Dunno much about feathers, so Im not sure if my claws will actually damage. Anyhow, grabbing hold while hes on my hinged wedge should allow me to push him around and hopefully to the pit.
Good luck AJ :)
Since there is nothing else to do, I shall write the last qualifying heat for Series Two
From England, OverDrive!
This was knocked out in Series One by Deadly Lampshade. It is still a box on wheels that rams other robots. Its invertible, but with no damaging weapon, the points could be stacked against it.
From England, Micrompression!
Lewis has entered this featherweight robot. It has two crushing claws and a wedge that works any way up. Its inexperienced, though.
3-2-1: Activate!
OverDrive charges forward and SLAMS into the front of Micrompression. The claws grab hold of AJs robot, but with four wheels, OverDrive pushes Micrompression into the arena wall! Micrompression lets go, but OverDrive pushes it again, into the angle grinder, but no damage is caused. Micrompression gets away and tries to get around the side of OverDrive. The claws grab hold again, but OverDrive drags it around with it. Micrompression pushing back, though, but the claws arent doing much damage. It lets go again, and OverDrive pushes from the side into the arena wall! Micrompression gets away, but OverDrive pushes from behind into the angle grinder again! Micrompression turns around to grab hold of it, but OverDrive pushes from the side again! Micrompression breaks free and presses the pit release button! Down goes the pit! OverDrive SMASHES into Micrompression from behind. One of the claws looks buckled on Micrompression, but it grabs hold of OverDrive and tries to push it into the pit, but OverDrive backs Micropression away! I think the claws have made their mark on OverDrive, but AJ refuses to surrender! Back goes Micrompression, it lets go, or has it? I think one of the claws is stuck onto the side of OverDrive! Lewis tries to get away, but AJ is in control now! Now Micrompression is free, but the claw is buckled even more now! OverDrive pushes it into the wall. The last ten seconds count down. Micrompression gets away and grabs hold of OverDrive one last time, but OverDrive pushes it against the wall. Lewis lets it go as the fight ends.
Cease!
That was a good fight. But the judges have to decide the winner.
OverDrive: S: 3 C: 3 D: 1 A: 3 Total: 10
Micrompression: S: 3 C: 3 D: 1 A: 2 Total: 9
It was close, but OverDrive is the winner! Well done to AJ.
And now, the lineup for the Semi-Finals!
Semi-Final One
OverDrive VS Sith
Toro VS UberForce 2.0
Typhoon VS Blizzard
The Hurting VS BIACS-IS
Semi-Final Two
The Red Knight VS Vertigo
Deadly Lampshade VS Little Flipper 3
Maleficant VS Armoured Wedgie
Typhoon VS Hyper-Ventilate
See you then! :)
Um...why is Typhoon in there twice? :S
Complete Control will take on Hyper-Ventilate
Sorry
It hasnt been long since the qualifying heats ended, and here we are with the first Semi-Final of FRFFT: Series Two!
First up: Sith and OverDrive!
From England, Sith!
Entered by Alex. It pushed Little Hitter into the pit to get here. A acuator powered flipper provide the weapons.
Entered by AJ. OverDrive is a box on wheels that pushes robots around. It beat Micrompression on a judges decision to get this far.
3-2-1: Activate!
OverDrive needs to avoid that flipper of Sith. It does so and tries to get around the side, but it goes up the wedge and OH! Sith THROWS it over! OverDrive isnt affected, it can run any way up, but Sith turns to face it again! OverDrive gets around the back and pushes Sith before it can turn around again! Into the wall, Sith, but it gets away and flips at thin air. OverDrive tries to ram it again, but drives up the angled wedge shape! OHH! Over it goes again! OverDrive turns away, but Sith gives chase. OverDrive gets along the side and pushes Sith around, but Sith turns and flips again! OverDrive recovers and tries to push Sith again, but Alex turns away and gets around the sides of OverDrive and THROWS it upside down! A good battle by Sith so far, I think its on top. OverDrive presses the pit release button. Sith chases after it, but OverDrive avoids the front and tries to get around the back. It does and it pushes Sith into the arena wall, but Sith recovers and turns around to flip OverDrive again! OverDrive comes around the sides again and pushes Sith over the flame pit! Sith breaks free of OverDrive and turns to the centre of the arena. OverDrive slides up the sides of Sith again, but gets away before its flipped. It comes in again and pushes Sith towards the angle grinder, but it slides up the sides of Sith again! Sith turns and FLIPS OverDrive over again! OverDrive gets around the back of Sith, but Sith is too fast and ALMOST into the pit there! OverDrive almost follows, but Sith rams it from the side...OHH! OverDrive is dangling over and DOWN it goes! OverDrive did well to get this far!
Cease!
OverDrive in the pit!
Sith goes into the Grand Final!
Well done to Sith
Perhaps you could have waited for AJs tactics first. :P
