quote:
Shouldnt I be somewhere near the bottom?Why would you need to be at the bottom?
Um...
I have never fought in an EOTR competition, and in the annihilator, I was the first one out!
Tricky. Very, very tricky.
Keep away from the front and aim for the corners of the skirts. Flip Rupture over, get underneath, shove it to the walls and get it OOTA before it can properly self-right. If penetrating the skirts proves difficult, Ill try getting round the sides and pushing it into the killsaws or flywheels. Even if they dont help me get under Rupture, Ill still rack up a few Damage points.
I dont think theres any real order...
Alright I might as well be the last person to sign up. Heres my bot:
Shape: Very low invertible box.
Colour: Body cyan, skirts light green, disc white with grey teeth.
Speed: 12mph
Weight: 100kg
Armour: 7mm titanium, 5mm titanium skirts
Drive: 2 S28-400 MagMotors running on 24 volts
Power: 4 NiCad Battlepacks running on 24 volts
Motivation: 2 wheel drive, Vulkalon rubber on the wheels for traction
Ground Clearance: 5mm under side and rear skirts.
Turning Circle: 0
Dimensions: 105cm x 70cm x 10cm
Weapons: Horizontal disc running on 2 S28-400 MagMotors on 24v. The disc is made of hardox, has a diameter of 60cm and weighs 17.5kg. The two 15cm long teeth are also made of hardox and weigh 2.25kg each, so the entire disc weighs 22kg, and thanks to that KE calculator, it produces 97.64kJ. Has a spin-up time of about 4.5 seconds.
Srimech: Invertible.
Strengths: Destructive weapon, good all-rounder otherwise.
Weaknesses: Tires can be hit by axes and crushers, high spin-up time for disc.
My tactics is to sit in the bar and wait for my turn :rofl:
Ill go with Dave :proud:
But sitting on that crusher wont be so comfy, Joey :wink:
Sit on the flipper :proud:
I have a cushion...
*produces wonderfully soft cushion from nowhere*
