6
6
Im guessing that makes Tsunami 3
The number is...1. :proud: Frank is correct.
That means NSBFR-X will fight Taki.
Tactics please, Frank. :)
Ill use the spinning bar, partly for the invertibility and also because it should mess up the Aluminium armour quite nicely. Her speed may be higher, but that means my control is better.
continuing...
I will, said NSBFR-X.
Are you quite sure, Frank old bean? said Clawdius.
Definitely, replied NSBFR-X. My spinning bar will do it. As he spoke the words, the spinning bar instantly replaced the scoop, and without another word he crossed the bridge to face the ninja, while the others looked on.
Good luck, Franky, said Flick, with a slightly amused tone.
So, youve come, said Taki, acknowledge this with a lift of the wedge.
Indeed, said NSBFR-X. Lets get it on. The bar started to spin up.
Then bring it!
Takis words echoed across the sanctum and she charged at NSBFR-X, quite fast actually, however NSBFR-X dodged it in the nick of time and Taki went sailing by, leaving her in perfect position to get hit by the spinning bar.
CRASH!!!
Perfect position, and perfect hit, as the aluminium armour was ripped clean off Takis side panel and she was spun away. She exposed her own blade now, and drove into NSBFR-Xs own weapon.
CRASH!!!
Another echoing blow, and both weapons stopped immediately, however NSBFR-X now had the advantage, as Taki had high-centered herself, driving right up onto NSBFR-Xs bar, and NSBFR-X driving to the edge dumped her off. At the last there was a wail, and she was gone.
The others hardly breathed. NSBFR-X had won in a major way...but what had happened to the ninja?
The question was answered almost immediately. Taki had suddenly appeared in a flash of blue light, right across from NSBFR-X, who turned sharply. She was in the same state from before NSBFR-X threw her off that edge, and the sounds she was making were plainly panting sounds: she had taken a beating.
You are...most definitely stronger than I am...although I hate to admit it... Taki panted, raising the wedge again. I will...join your crusade for now...but after I slay the king...I will decide if I wish to remain with you...or not.
Fair enough, said NSBFR-X. Need a - ?
No, thank you, I carry my own, said Taki, using up a Tool Kit, healing herself instantly. I carry two more, in case any of you are ailing or in need.
Great! said Flick. Now lets go kick bot!
YOU HAVE ACQUIRED A NEW PARTY MEMBER: TAKI!
You have acquired 2 Tool Kits!
The party, now increased in number, left the sanctum, and the tunnel, and came out into the fresh air...only to halt at the sight of several elite ninjabots all pointing their weapons at them.
Okay, THIS isnt good, said Tsunami.
ENCOUNTER!
Fu-Ma Ninjabot x 5
Shape: Nightmare (from Battlebots)
Weight: 150kg
Speed: 10mph
Armour: 3mm hardox
Weapon: A giant spinning disc, going at 1500rpm with four hardox teeth.
Srimech: None
Items in Stock
3 x Tool Kit
1 x Power Boost
Party Members
Tsunami
Taki
If some robots distract them, I think myself and Tsunami could flip them over quite easily. If they hit Tengu, it might be pretty entertaining.
Agreed. Methinks we can take on one Ninjabot each while the three flippers dash about and do their stuff. Taki is welcome to join in too if she feels fit enough.
Perhaps try talking to them first? Failing that go for the wheels.... considering what Warhead could do to Nightmare, an fbs could certainly be entertaining.
Well, considering what Son of Whyachi can do to Nightmare...considering what Mauler can do to Nightmare...
Well I havent seen those but I have seen Warhead :P
