Side strips to avoid getting stuck on its side 8mm aluminium water cut
Very nice!
Ceros new flipper arm 6.35mm t6 aly with 5mm aly braces and 5mm ti sides with 20mm steel bar for the ram to work on just need to make the hardox snow plough,
bettle weight spinner under construction 500gram drum mounted on 10mm bearings
http://www.youtube.com/watch?v=mFRDrX9slpY
ceros flipper test video
Is that a seat belt your using as a tether? How do you connect it at each end? Looks good btw.
Two holes and a flat clamp
4mm hardox scoop cut ready for bending and nylon collar to reduce ram stroke from 120 - 97mm in design, should have a new update by next weekend,
notoy has new 4mm aluminium base and is about 50mm smaller length and depth, gr01 fitted and axe mount cut
Final test c02 using one of trevs regs, starts at 8bar up to 12bar, includes new 4mm hardox scoop shortened ram know have 95mm stroke still plenty, just using the steel single buffer tank. seatbelt arm restraint straps with 4x8mm bungee on each side to close the arm, also all final fitted armour.
enjoy
http://www.youtube.com/watch?v=CVy0KEioEaE
That's looking amazing adam! Can't wait to see it on FP
id keep it low pressure mate, seems to have plenty of poke and will out last all the big flippers, will work well with your powerful drive... works for behemoth and makes for a more entertaining show.
