The Fowler Fic War Series 5
Right, I know I€™ve been a bit lax with the last 2 series, it€™s because I€™ve had a lot going on in the last few months, and thus I€™ve struggled to find time to design or write, but I now plan on becoming full-time again, but to get me in the swing of things FFW5 is going to be a smaller tournament than before.
The idea:
FFW5 is going to be a UKRW2 style series, with 12 heats of 6 robots. I will therefore be looking to have 9 people enter 8 robots each. At least 4 of your 8 robots must be vapours, however there is no necessity to have a realie. Each heat will start with the gauntlet and then a trial before going into the usual arena stage. The advantage for seeds in this series, is that they get a bye through to the arena stage of the heats, meaning it€™s harder for unseeded robots to get through round 1.
The weight limits are as follows
Wheeled/Tracked/Shufflers - 100kg
Walkers - 160kg
Any other motivation - Ask if appropriate.
For the gauntlet, the routes will be similar to UKRW1 and 2 but with some differences.
The entrance will be the cage as the turntable was proved to be flawed in series 1.
Route 1 (left) - This route is solely house robots. Shunt, Sgt. Bash and Matilda will all be in the way, and to get through them, you will need to use any means possible
Route 2 (middle) - After breaking through the wall of breeze blocks, you will be required to go over 1 of 2 ramps. The end of the route is divided into 2, so the steeper ramp has an easier ending, with just the pendulum and the arena spikes to negotiate, while the left route will require you to get past Dead Metal who you will have to push backwards to get through as the route is so thin. The ramp however, will be far easier to get over though.
Route 3 (right)- The start of the route is the maze from series 1, before coming across the ram rigs, so hated in series 2. the last section of the route has just Sir Killalot, and he is not allowed to come further down the route, therefore you will just need to negotiate that section while facing him.
Unlike series 2, where each trial appeared twice, there will be 12 different trials, including some I have invented :proud:
The list is as follows with an explanation of those I have invented:
Sumo
British Bulldog
Football
Speedway
Maze
Snooker
Joust
Skittles
Tug of War
Pinball (Semis only)
Turntables - The idea of turntables is to show your driving skill without any house robots in the way to harm you. The idea is simple, 5 turntables with no walls with platforms in between. Negotiate your way from one end to the other to be successful.
Conveyor Belt - The idea of this event is show to show your level of traction. Your robot will be placed at the end of a conveyor belt and will be expected to reach the other side in as quick a time as possible. You have 30 seconds to do so, in the event of not reaching the other side, then the furthest point your robot reached will be it€™d final score.
Karate Chop - A wall of breezeblocks, 5m thick faces you, and you must get as far through them as you can. This is designed to show your robots force, strength and ability to negotiate obstacles.
That€™s all the info I can think you should need for now, but if any more is needed feel free to ask.
Ill be entering all vapours...
1: Orka MK4
2: Die-Ceratops Re-Invertus
3: Leprosy Infection
4: Mega Masher 2
5: Y4
6: Axe-O-Lotl
7: Crash Bandi-Bot
8: Spring-BOK!
Im sure you know where to find stats.
expect my stuff tomorrow Matty
Team Braveheart ahoy! :proud:
1) Wedge Devolution
SHAPE- low wedge with sloped rear and Biohazard-style side and rear skirts
COLOUR- sleek and shiny silver
WEIGHT- about 100kg
DIMENSIONS- 90cm X 78cm X 40cm
SPEED- 16mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot (without skirts), 0mm at all sides (with skirts)
ARMOUR- 4mm Hardox
WHEELS- inside robot, 4-wheel drive
POWER- 12 x 12v 3amp NiCad packs, giving 36v @ 12amp; 2 x LEM-COs at 36v for drive
WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. According to Dannys flipper calculator (making the flipper 6kg and the amout of gas aboard 2kg), Mr Devo should use about 34 flips per fight and throw approximately 816kg in total.
Also, the front blade can be exchanged for a Nose-style plate, approximately 15cm in length. This is used primarily for full-body spinners, but hardly ever used.
SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
NOTES- flashing red light on top of robot, flies Scotland flag
STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers)
2) Killotine: EVO
SHAPE- compact box shape with a front Storm 2-style wedge and spatula for getting under other bots
COLOUR- red
WEIGHT- about 100kg
DIMENSIONS- 100cm X 70cm X 35cm
SPEED- about 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front, 10mm at sides and back without skirts, 0mm at sides and back with skirts
ARMOUR- 15mm polycarbonate top and bottom, 3.25mm Hardox armour at sides, front and back
WHEELS- inside robot, 4WD
POWER- 2 X LEM-130s
WEAPONS- The main weapon is the large 180 degree pneumatic axe, very similar to that of Killerhurtz. It operates at 160psi with a rack-and-pinion system like Terrorhurtz. The axe is composed of 3.5mm Hardox, but if anything should happen to it, the robot can use its great pushing power to resort to a Tornado-style tactic - ram to death!
SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. The machine also has a rounded back and a red semi-sphere on either side of robot to stop it landing on its side.
NOTES- flies the Scotland flag
STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
WEAKNESSES- so-so turning
3) Metal Sonic Spin Dash
SHAPE- low skirted box, with fixed front wedge & sloped sides
COLOUR- blue bodywork, with red-and-white striped skirting
WEIGHT- about 100kg
DIMENSIONS- 102cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at front with spatula, 0mm elsewhere with skirts, 12mm elsewhere without skirts
ARMOUR- 3.75mm Hardox
WHEELS- inside robot, 6WD
POWER- 2 x LEM-130 MagMotors. These will run at 36v and produce approximately 18hp.
WEAPONS- The main weapon here is really the excellent traction, but like all its other incarnations, Spin Dash still maintains its Pussycat-style vertical saw blade, running at 3000rpm. This time, however, the four-clawed spinner sticks halfway out of the front wedge, so that when the wedge/spatula combo bashes underneath an opponent, both the wheels and the underbelly are at the mercy of the saw.
Also features several Mute-style barbs on top to hook onto other robots and let me drag them around the ring
SRIMECH- a rear-hinged arm on top with a basic low-pressure CO2 set-up. Can be used to about 30-40 times and is ONLY used for self-righting in order not to waste the gas supply
NOTES- flies the Scotland flag (though, forgot to add to pic. Shockaroonie!), has F*** Shadow! written on the underbelly in red
STRENGTHS- excellent traction, fast, manoueverable, tough armour, well-skirted, great at getting under everyone else
WEAKNESSES- so-so turning ability, teething troubles?
PICTURE- http://img77.imageshack.us/img77/3603/fifthspindashde6.pnghttp://img77.imageshack.us/img77/360...pindashde6.png
4) Whirligig 4.0
SHAPE- flat disc
COLOUR- deep yellow with Mauler-style scary face on top
WEIGHT- about 100kg (see bottom)
DIMENSIONS- 101.6cm diameter X 12.7cm
SPEED- 15mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 4mm
ARMOUR- 1.905 cm thick Grade 5 titanium
FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
WEAPONS- the main weapon on Whirly 4.0 is a much improved spinning shell. Weighing in at 33.72kg overall, its heavier than before and now boasts 9 Pussycat-style blades - 3 on the top, 3 in the middle and 3 on the bottom, so it can get some scars in nearly all opponents. The shell is now powered by 2 X LEM-130s running at 36v (these lie on their side, so they will fit comfortabely inside Whirly). These produce 2000rpm...and 183 kilojoules. This should be enough to completely obliterate another machine. Or worse.
As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
NOTES- Mauler-style scary face on top and bottom which show direction of robot, flies Scotland flag, my first properly calculated machine
STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
WEIGHT CHECK:
armour = 33.72kg (inc blades)
chassis, mounts, bracing etc = about 30kg
drive and weapon motors = 12kg overall
NiCads = about 15kg
feet = about 10kg overall
TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule.
5) Clawdius Decimus Murderous
SHAPE- wedge with small box section and high rear wedge
COLOUR- deep green with shield emblazoned on the wedge
WEIGHT- about 100kg
DIMENSIONS- 95cm X 73cm X 70cm (including claw - 35cm without)
SPEED- 13mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
ARMOUR- 5mm Hardox
POWER- 2 X S28-300 MagMotors (thanks to Scott here)
WEAPONS- The main weapon is the Razer-style crushing claw, operating at 3000psi (5000 if permitted in certain tournaments), with a nice little diamond-coated tip. Also at the front is a Firestorm-style blade and 2 small €œspears€ to aid in getting under the opposition. Combined with the crusher and the reasonably powerful 4WD, CDM can become an effective pusher/clamper
SRIMECH- Like before, CDM uses a rear-hinged pneumatic arm on either side to self-right. The high-wedged rear also prevents the robot getting perched there
NOTES- flies the Scotland flag, concept of name came from €œGladiator€ (€œMy name is Maximus Decimus Meridius - father to a murdered son, husband to a murdered wife...but that€™s when I phoned Claims Direct!€Â)
STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fast srimech
WEAKNESSES- so-so manoeuvrability, slow weapon
6) Chameleon
SHAPE- simple box with removeable front section and removeable Biohazard-style skirts all round
COLOUR- so damn silver and shiny, you can see your face in it...ugly, innit?
WEIGHT- about 100kg with the heaviest set-up
DIMENSIONS- 80cm X 80cm X 30cm
SPEED- 12mph
TURNING CIRCLE- 0m, using a skid-steer system
GROUND CLEARANCE- 0mm all round (with skirts & scoop), 10mm all round (minus skirts & scoop)
ARMOUR- 4mm Grade 5 titanium
POWER- 2 X C40-500 Magmotors. This will run at 36v and produce about 12hp.
WEAPONS- Just take your pick:
(1) The Anti-Flipper Device - Flippers are most vulnerable when theyre open. The idea I have is a very low front scoop (with flat spikes along the bottom to aid in sliding under others ala Barry) and a small 3000psi crushing arm (like a smaller version of Plunderbird 5s) The idea is that the flipper tries to get under and flick you over, it fails, then before the flipper shuts, you twirl round, slide under and crunch into the innards
(2) The Anti-Axe Device - The set-up here is the scoop and crushing arm again, which will be used for sliding under the opposition and snapping the axe arms in two. I can also use this set-up to simply slide under the sides, grab hold and drag it around, since the axe wont be able to hit me
(3) The Anti-Vert Device - This set-up is used against vertical spinning discs and consists of a small set of horizontal hydraulic jaws running at 3000psi. Made from about 3 mil Hardox, these are used for clamping onto the disc, allowing me to drag the offenceless opposition where I see fit
(4) The Anti-Horiz Device - This set-up is used against vertical spinning discs and consists of another set of jaws, but these are very similar to Growler (with a Bigger Brother-style blade on the bottom jaw for sliding under the opposition). Also running at 3000psi and made from 3 mil Hardox, this wide jaw is designed to clamp onto the disc and once more allow me to drag the bot around the ring
(5) The Anti-Wheel Device - This is used against robots which lack skirts and is a horizontal Pussycat-style saw mounted on the bottom of the bot (ala Code:Black). Spinning at 3000rpm, the blade can slide under the exposed ground clearances of these bots and tear the wheels to shreds.
(6) The Anti-Fodder Device - This set-up is used against robots with weak(ish) armour and consists of the front scoop again, which leads up to a vertical spinning blade. Powered by a B42-500 Magmotor at 60v, it is geared at 15:1 and can easily reach speeds of 2000rpm and quite easily take the weaker machines apart
(7) The Anti-Crusher Device - This consists of several Hardox spikes (8 along each side, to be precise). Each prong is about 30cm long and are designed not only to keep the crushing arm away from the main body, but also to properly damage the opposition while ramming
(8) The Anti-Pusher Device - This is a very basic set-up, as Chameleon will simply be armed with Biohazard-style skirts on all 4 sides. The idea is to scoop up the pusher on one of the skirts and to shove it around using my 12hp.
(9) The Anti-Obliteration Device - This is used for the most horrible spinners like MDU and King Cholera and can also be used for axlebots if need be. The weaponry here consists of a static Behemoth-style scoop (made of 6 mil Hardox and with a Firestorm-style blade along the bottom) and a medium-sized set of Tough As Nails-style clamping jaws with small spikes on the inside for better grip (also made of 6 mil Hardox). The idea is that the spinner hits the thick scoop, the shell stops and the jaws are then able to grab hold of the machine. Then, the bot can be shoved and dragged wherever I see fit (thats the idea, anyway)
SRIMECH- The machine uses a Firestorm-style flap on top to flick the robot back onto its wheels. Running on low pressure gas, the srimech will last for a long time before running out. Also, a semi-sphere on either side of the bot (made to look like the Chamelians eyes ) prevents it getting beached on its side
NOTES- flies Scotland flag
STRENGTHS- interchangeable weapons, good armour, good control, good manoueverability, high pushing power
WEAKNESSES- could prove weaker against stronger pushers
If theres a limit to the number of set-ups, Ill use #1, 3, 4, 5 and 6.
7) Behemoth (RW7)
8) Big Nipper (RW7)
Vapours:
Agro 3.5
Battle Raptor IV
Drilla Killa VII
Megalodon Maneater
SYNDOS
Tenderizers Revenge 2
Realies:
Razer (RW6)
Storm 2 (RW7)
Heres the stats for Agro 3.5 and Megalodon Maneater - the others can be found on Mechanical Noise S2:
AGRO 3.5
Weight: 100kg
Shape: Low invertable wedge with a low square hinged plate at the front
Dimensions: 85 x 65 x 40 (cm; l x w x h)
Speed: 17mph
Ground Clearance: 0 at front due to hinged plate, 1cm at sides and rear
Armour: 4mm Hardox
Wheels: 2, inside robot, and RC gyro for added control
Power: 2 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapon: The hinged plate at the front allows 0 ground clearance - it can surpass skirts with a good push. At the rear is a 10kg 3000RPM X Terminator-like vertical spinning disc at the rear, made of titanium and powered by a D-Pack.
Srimech: Invertable.
Tactics: Try to get under opponents and shove, or use the rear disc on them.
Strengths: Fast, manouverable, dangerous weaponry
Weaknesses: A little tricky to control, high ground clearance
MEGALODON MANEATER
Weight: 99kg
Shape: Wedge, painted blue, with sloping rear with shark fin sticking out of it, and rollcage at top
Dimensions: 90 x 50 x 40
Speed: 13mph
Ground Clearance: 0 at front due to wedge, 0 at sides and rear due to skirts, 3mm behind skirts
Armour: 4mm Hardox
Wheels: 4, inside robot
Power: 4 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapon: Razer like vertical hydraulic jaw at the front, on the wedge. The jaw is on an arm so as it lowers, it moves downwards and forwards to grip and crush the other robot (this is for skirted opponents which the wedge cant get under).
Srimech: Rollcage works as srimech; cant rest on rear because it slopes; screws tapped into sides mean it cant rest there
Tactics: Just grip and crush
Strengths: Weapon can attack skirted opponents; protected wheels; harder to flip
Weaknesses: Not especially fast
(Message edited by velociraptor on October 30, 2007)
Im going to enter:
MeCannibal
Invertex
Crusher C.U
Terrorhurtz
Tornado
Iron Awe 5
AND...
Sky Blast
A rather generic line up for me:
Slammer V
Archangel of the Abyss
Salamander III
Tengu VII
Slaying Mantis F
Achilles
Scarmanga II
Black Panther Queen
http://www.alexjholt.tkwww.alexjholt.tk as normal
Add Hyena to my list. (Thanks Chris for noticing)
If its OK, Id like to reserve some spaces. Ill need some time though as Im going to be making a new squad from scratch (more or less, knowing me)
http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
Ill be entering
Flick of the Wrist
Axe to Fall
Liar
Back to Rock 2
A Night at the Bar
Sheer Heart Attack (Ill need some time to bring it back to 100 kg though :sad:)
and two realies; Firestorm and Storm 2
Wedginator 5.0
The Epidemic
Seung Mina II
Dysfunction 2.0
The Grand Disillusion
Shadow Zone
Intrigue
Cortez 1.1
http://www.vapourbots.crystalnode.net/forum/viewforum.php?f=10&sid=b252e66a8d4f93bf911cbec2bbb 3e950http://www.vapourbots.crystalnode.ne...=b252e66a8d4f9 3bf911cbec2bbb3e950
I think all spaces are filled, but if not save one for me please.
well I accidentally let it get to 10... so I may as well go for 12 with 8 and have a bigger tournament =.
So I just need 1 I guess. could people get at least the names of their entries in soon please.
http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
Sengazanken
All Apologies
Shovearound 2
SUNCUST
Cyberdemon
Terror Gear 3
Shotgun Slapper
Mr. Slave 2
kk
Just so everyone knows, my line up is:
Tempest Evil-est-oution
The Disc 6
IDSFA or maybe ISDSFA - It doesnt stand for anything or it still doesnt stand for anything
The May Tracks Has You
Dead Horse Beater
Door Stops
SBPOTFR - Seen before plenty of times fic robot
ARWARLNSBILA - A robot with a really long name simply because I like acronyms
I hope to start getting stats and pictures up during next week.
With those names, I can tell this is gonna be good. :proud:
Please, people, lets not have another hypothetical FFW. =P
Sorry for the delay, Ive been out of the game too long. Having some trouble getting the stats done.
Currently no internet at my new house, currently posting from work... Will have internet back this week...
8 sets of stats coming this weekend....
Id like to make a new list of contestants for my team:
5 VAPOURS
3 REALIES
1 . Knock-Out
€ WEIGHT: 100KG
€ ARMOUR: 7MM HARDOX FRONT. 8MM ALUMINIUM BORON CARBIDE ELSEWHERE. THE WHOLE SHELL IS MONOCOQUE. THE WHOLE SHELL HAS 450 WEIGHT REDUCING HOLES IN IT.
€ SHAPE: PYRAMID WITH TOP POINT CUT OFF. THE CORNERS OF THE WEDGE ARE CUT OFF AND THE REAR IS ROUNDED
€ MOTORS: 2 x ETEKS AT 46V = 30HP
€ LOCOMOTION: 4 x VULKANISED WHEELS
€ DIMENSIONS: (L) 90CM (H) 40CM (W) 50CM
€ COLOUR: THE ARMOUR IS WHITE ON THE REAR AND SIDES AND HAS FLAMES ON THE REAR. THE SCOOP AND AXE ARE BOTH BLACK.
€ WEAPONRY: A 15KG TERRORHURTZ STYLE AXE, ALL MADE OF HARDOX. THE HEAD IS BLUNTED, AND HAS HARDOX SPIKES ON SIDES. IT€™S POWERED BY AN 80MM 1000PSI BORE RAM. 3.6 TONNES OF FORCE AT THE TIPS. TO PROTECT IT AGAINST SPINNERS 3 INCHES OF TITANIUM FOAM IS PUT IN TO PROTECT IT.
€ SPEED: 26MPH
€ GROUND CLEARANCE: 0MM AT THE FRONT BECAUSE OF SCOOP WITH EXTENSION. ON THE SIDES THERE ARE 6MM AND AT THE REAR THERE€™S 10MM, EXCEPT IS TOUGH TO GET UNDER.
€ STRENGTH: DEADLY TO ALL INVERTIBLE ROBOTS.
€ WEAKNESS: EASILY FLIPPED
2. MeCannibal
€ WEIGHT: 110KG (SHUFFLER)
€ ARMOUR: 5MM HARDOX
€ SHAPE: INVERTIBLE LOW CYLINDER
€ LOCOMOTION: 2 SHUFFLING PADS
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 15CM
€ COLOUR: BLACK WITH SCARY HUMAN FACE WITH OVER SIZED TEETH COLOURED RED.
€ WEAPONRY: RING SPINNER, MADE OF 20MM HARDOX, WEIGHTING 38KG, SPINNING AT 3500RPM, PRODUCING 205KJ PER BLOW. IT HAS 6 BLUNTENED TEETH MADE OF HARDOX. THE TEETH ARE SET IN A TRIANGULAR SET UP. HAS 5 INCHES WORTH OF TITANIUM SHOCK-PROOF FOAM TO STOP IT SELF-DESTRUCTING.
€ SPEED: 22MPH
€ GROUND CLEARANCE: 0MM-4MM. IT HAS A FULL-BODIED SKIRT RUNNING COMPLETELY ALONG THE GROUND THAT RAISES WHEN THE SHELL IS SPINNING BUT DROPS WHEN THE SHELL ISN€™T SPINNING.
€ STRENGTH: SCARY NAME AND WEAPON
€ WEAKNESS: HARD TO CONTROL
3. Down-Force
€ WEIGHT: 100KG
€ ARMOUR: 5MM MONOCUQUE HARDOX ON FRONT REAR AND TOP. 6MM ALUMINIUM BORON CARBIDE FOR
€ SHAPE: BOX WITH SLANTED SIDES AND REAR
€ MOTORS: 2 x LEM 130 AT 46V = 18HP
€ LOCOMOTION: 4 x VULKALON TREADED WHEELS ON TOP AND BOTTOM ALA BIG NIPPER
€ DIMENSIONS: (L) 50CM (W) 50CM (H) 35CM
€ COLOUR: BLACK FOR THE BODY, SILVER FOR THE CRUSHING WEAPON AND SCOOP COMBO
€ WEAPONRY: THE WEAPON FOR THIS IS A BIG NIPPER STYLE CRUSHING/LIFTING ARM, BUT INSTEAD OF CLAWS TO LIFT WITH, IT HAS A SCOOP WITH AN EXTENSION AND A RAZER STYLE CRUSHER. THE WEAPONS LIFTS AND CRUSHES WITH A FORCE OF 5 TONNES! IF THE ROBOT IS FLIPPED THE CLAW IS USELESS, BUT LIKE BIG NIPPER, IT CAN SELF-RIGHT!
€ SPEED: 23MPH
€ GROUND CLEARANCE: 0MM - 5MM. 3.25MM HARDOX SPRUNG SKIRTS ON THE SIDES AND REAR MAKE IT A NIGHTMARE TO GET UNDER.
€ STRENGTH: POWER, SPEED AND WEAPONS MAKE IT A TOUGH MACHINE
€ WEAKNESS: IF FLIPPED, THE WEAPON CAN€™T BE USED, BUT IT CAN ALWAYS SELF-RIGHT!
4 . Nitro-Gene
€ WEIGHT: 100KG
€ ARMOUR: 4MM HARDOX
€ SHAPE: LOW INVERTIBLE BOX WITH SLANTED SIDES AND REAR LIKE TORNADO
€ LOCOMOTION: 6 VULKANISED WHEELS.
€ DIMENSIONS: (L) 80CM (H) 16CM (W) 60CM
€ COLOUR: RED
€ WEAPONRY: A FULL PRESSURE NITROGEN FLIPPER AT THE FRONT. AT THE FRONT IS AN EXTENSION MOUNTED UNDER THE FRONT TO GET UNDER AND BRING THEM ONTO A NITROGENT POWERED FLIPPER THAT RUNS UP THE FRONT OF NITRO-GENE, AND DOWN BY 30CM. THE FLIPPER HAS ENOUGH POWER TO LIFT 1500KG.
€ SPEED: 18MPH
€ GROUND CLEARANCE: 0MM-2CM. AT THE FRONT ITS 0. AT THE SIDES AND REAR ITS 2CM.
€ STRENGTH: PUSHING POWER AND WEAPONRY.
€ WEAKNESS: HIGH SIDE GROUND CLEARANCE.
5. A.R.R.T.D.S
€ ARMOUR: 8MM HARDOX MONOCUQUE. 600 HOLES HAVE BEEN DRILLED IN TO REDUCE WEIGHT
€ SHAPE: INVERTIBLE BOX WITH FLAT FRONT, SIDES AND REAR
€ MOTORS: 2 x C42-500 MAGMOTORS AT 60V = 60V
€ LOCOMOTION: 2 x SHUFFLING PADS
€ DIMENSIONS: (L) 90CM (H) 20CM (W) 90CM
€ COLOUR: BLACK/WHITE STRIPES
€ WEAPONRY: NONE.
€ SPEED: 30MPH
€ GROUND CLEARANCE: 0-5MM - SKIRTS ON ALL SIDES MADE OF 5MM HARDOX PREVENT ANYTHING UNDERNEATH ANY OF THE SIDES.
€ STRENGTH: SPEED AND POWER
€ WEAKNESS: NO DAMAGING WEAPONS
6. Tornado (realie)
7. Turbulence (realie)
8. Tough As Nails (realie)
Paul, you might want to look up what a monocoque is...
I know what a Monocoque is, its a robot that is built chassis first and the other compounments are mounted on.
There is no way on earth you will get a 15kg axe merged with 2 Eteks and armour as thick as that in 100kg. No matter how big you make those 450 holes.
LMFAO @ Paul..
I dont want to be rude, but please do some research, gain a bit of knowledge :proud: Its extremely obvious that your just chucking things together without putting any thought behind them.
Anyway, Ive had my dig, this is entirely up to Matty
I agree with Aaron: if you cant make proper vapourbots yet, DO SOME FREAKING RESEARCH.
This is getting tedious, really fast.
Ill have a go at a vapour bot, seen as i cant actually build anything while im away, i guess its jus a plan of what a robot could be?
Craigs Robot And Proberbly Blaitently A Gash or CRAPBAG
€ WEIGHT: 96KG
€ ARMOUR: 6mm Hardox flipper 4mm hardox else where, fully welded body with boxsection frame
€ SHAPE: Multi-Angeluar wedge, pic on my flickr page ill post a link later
€ MOTORS: 2 S28-400, on 24v limited by roboteq
€ LOCOMOTION: 150mm dia 40mm wide vulk wheels ally hub
€ DIMENSIONS: (L) 750mm (H) 230mm (W) 550mm
€ WEAPONRY: a full pressure flipper 110mm bore ram, 100mm stroke 3 burket input from base, buffered from a half co2 bottle powered by 2x CO2 bottles (same set up as Beast 2 years ago), flipper is made from solide boxsection with 6mm hardox plate mounted on top (welded)
€ SPEED: 15mph
€ GROUND CLEARANCE:on the floor at the front around 10-15mm ath the back same as i had on tx-108 and that got under storm 2 with ease
€ STRENGTH: the flipper i guess
€ WEAKNESS: rookie vapour bot dont actually know what im doing
there that ok? ill design it and post the link wont be long
That is a good vapourbot design Craig...except for the name. :proud:
What batteries, voltage and how many amp/hours, Craig :wink:
http://www.flickr.com/photos/tanto818www.flickr.com/photos/tanto818
Come on now, if people are going to kick Paul out for being unrealistic, its only fair I get the boot as well, as Im just as, if not more guilty of the crime.
Craig, given your knack for building small i can see that being within 100kg. It would be a nightmare to service though. But vapours dont need repairs. :)
yea, burkets would be a bugger to fix, but the rest should be ok, i totted it up to 83kg actually with gas!
you got some good designs craig. mabee i should build one. :)
Can you tell what i was thinking of when i designed thorn?
build what ever you want shane but leave TX-108 and Tanto alone or ill errr (pauses for thought while he remembers shane is bigger than him) I wont bring u any beer back from australia
Is it wrong that its 10 in the mornign and Im excited by the prospect of beer? =/
I think I have a problem =/
If Id saved all the money Id spent on beer over the years I could probably have built a realie by now, lol
Probably :proud:
Hey Matt, could you put the list of entrants and places needed to be filled? Im kinda confused as to how many people have entered and have reserved spaces.
No worries, will do it later when Im not gonna be under the influence of plants
