Antweight Database
usual stuff
Robot - R2 (Rebel)
Speed - 1mps
Power - 1x6v nimh
Drive - speed hacked naro hp bb / picos
Controller -
Weapon - pneumatic flipper
Armour - 0.5mm compressed carbon fibre
Status - semi-retired
Photo - http://www.cummins.pwp.blueyonder.co.uk/rebhome.jpeghttp://www.cummins.pwp.blueyonder.co.uk/rebhome.jpeg
Antweight Database
Robot - Gravant
Speed - 1 M/s
Power - 6 volt nihm 200 mamp
Drive - Speedhacked Jamara Pico 5.4 gr
Controller -
Weapon - Pneumatic flipper
Armor - 2 mm PC, 1.5 mm Polystyreen, 16mm ALu
Satus - Almost finished
Foto - nope
Antweight Database
all though r2 is semi retired it will be coming to the odd event now and again... however im going to probally build it out of polycarb as the CF although it looks gorgeous its over a year and a half old so time to try somethng new :)
http://www.c2robotics.co.uk
C2
Antweight Database
Speed: dunno, fairly slow
Power: 7v 50mAh NiCad
Drive: SD200
Weapon: 2 servo flippers
Armour: Loads of different stuff, just got some Ti!
Status: alive and fighting
photo: on http://www.blazerbotics.co.ukwww.blazerbotics.co.uk
Notes: European champion
Antweight Database
Name: CombatANT MilitANT ANTicyclone DominANT
Speed: Slow Slow Slow Fast
Power: 12v LiPo 12v LiPo 12v LiPo 5v NiMh
Drive: Naro HP Naro HP Naro HP S135 SpdHk
Weapon:Spinner Spinner Spinner Wedge
Armour:Polycarb PolyCarb PolyCarb PolyCarb
Status:Fighting Fighting Fighting Fighting
Antweight Database
Robot - Ants Revenge 2 (AR2)
Speed - 25cm/s (estimate)
Power - 6V Ni-MH
Drive - Naro HP (x2)
Weapon - Vertical Titanium Disc (65mm)
Armour - 1mm & 2mm Polycarbonate
Status - Nearly Built
Robot - ADB
Speed - 24cm/s (estimate)
Power - 4.8V Ni-MH
Weapon - Flipper
Antweight Database
Anto
75cm/s
2xLiPo cells
S136L SPHK
Rambot Titanium rams
none
Burnt out but running in 2 days
Antweight Database
Robot = Devils Advocate
Speed = Currently nil
Drive Hitec HS-55 (x2)
Weapon = Scoop and axe
Armour = Polycarb
Status = in the pipeline
Antweight Database
Speed: ??
power: 4,8V NicAd
Drive: Jamara Power micro
Wepon: Flipper
Armour: Plexi
Status: Rebuilt
Antweight Database
ADB (see above somewhere) now has a pneumatic flipper... and here is my team-mates antweight.
Robot - Frogoid
Speed - 30cm/s (estimate)
Power - 4.8V Ni-MH
Weapon - Naro HP Powered Lifter/Flipper
Armour - Used To Be A Computer Mouse (Frog Mouse)
Antweight Database
Speed: ???
Power: 4.8v NicAd
Drive: 2x Saturn s-49
Weapon: Pneumatic Phillipa
Armor: Card at the moment
Status: just built and ready to roll
Antweight Database
Bushido Embreyo
speed- upto 120cm/s
Power-2lipo cells
drive- tamya gear box
weapon-speed
armour-polycarb
status- ready for combat
Bushido Lobedo
speed-unknown
power-2 lipo cells
dive-4xsaturn 49
weapon-lifter
armour 1mm Aluminium
status ready for combat
Anto XP1HP
speed- 2.1m/s
power-4 lipo
drive- custom motors
weapon-titanium L spikes
armour-1mm titanium, 1mm aluminium
status- being developed
Antweight Database
Speed: unknown
Power: 4.8v NiMH
Drive: Two DragonFly 9g servos (basically HS-55 Servos)
Weapon: 30g Spinning Drum
Armor: 1mm polycarb
Status: Waiting for parts to arrive
Antweight Database
ok lads good news on the ant front
im building a new website and it will have ant database
pics are mandaotry so if its not a finished robot you cant add it.
will post a link wen its up :)
Antweight Database
Robot - Lower
Speed - 25cm/c
Power - 4.8V Ni-Mh
Drive - Saturn 62s
Weapon - 1.3kg Crusher
Armour - 1mm Aluminium & Gaffa tape!
Status - Ready to rumble!
Robot - Resurrected
Speed - 20cm/s
Power - 4.8V Ni-Mh
Drive - Saturn 62s
Weapon - 2kg+ Crusher
Armour - 1mm aluminium
Status - Ready to chew through more coke cans!
Robot - FluorescAnt
Speed - 50cm/s
Power - 6V Ni-Mh
Drive - SD200s SP HK
Weapon - Axe
Armour - 1mm Polycarb & Warning tape
Status - Built
Antweight Database
My new Antweight is
Robot - ANTrax
Speed - Reasonable
Power - 12.6v LiPo
Drive - NC1 motors driving tracks (SOZBOT Controller)
Weapon - Twin titanium lifters
Armour - Titanium Bulldozer Blade
Staus - Ready for action
Antweight Database
I wondered when yous build something like that pete :) It sounds rather excellent- any pictures?
Antweight Database
sounds good peter :)
bringing to aws14?
also everyone here.. aw.com is now up
the database shoudl be up soon.
when it is please please please sign up and add your bot
Antweight Database
Robot - Anticide
Speed - Fast-55cm per second
Power - 300mah 6V Ni-Mh
Weapon - flipper/lifter sd150
Armour - 1mm Polycarb double layered at the front and sides with a fine woven cloth between them. 0.25mm aluminium bumper
Status - Being upgraded from 4.8V so some weight needs to be saved, but should be ready for rrc 18th sept
Antweight Database
Name - Flippt!
Speed - 1m/s
power - 150 mah 4,8V Ni-Cd
Drive - Jamar power micro (old ones)
Weapon - lifter Graupner C341
Amour - About 1 mm plexi
Status - About to be stripped and make a new shell out of 0,75 mm polycarbonate.
picture will soon be in my profile. Need to size it down a bit.
Antweight Database
Name - DiskStructAnt
Power - Lithium Polymer batteries
Drive - GWS HP NARO BB (x2)
Weapon - 30g Vertical spinner with stanley blades
Armour - 2mm Polycarb
Status - Finished but cant find a crystal in the UK to test it. Runs on 40MHz.
Picture - check out my profile
Antweight Database
Apart from the lack of grip, that is a very nice looking robot. What is your weapon motor BTW?
http://www.sussex-model-centre.co.ukhttp://www.sussex-model-centre.co.uk for crystals.
Antweight Database
This is my new ant
Robot - ICant(inverse crusher ant)
Speed - 100cm/s(guess)
Power - 6V 300mah Ni-Mh
Drive - SD150 speed hacked
Weapon - 1kg inverse crusher(one servo that crushes and lifts at the same time)sd200 servo
Armour - 1mm polycarbonate chassis but needs more armour
Status - Running and is very effective against my other ant. it is currently overweight but I can save weight all over the place.
Pics and diagrams at the bottom of http://www.freewebs.com/anticidewww.freewebs.com/anticide -more diagrams to come as no one understands the weapon.:)
features two self righting arms, they were described as annoying by a friend.
Antweight Database
Thank you, Ive used a RC car silicon fuel pipe as tyres for the wheels and I get a fair amount of grip from it. The motor Im using came out of a scalextric (slot car) type toy.
Tried Sussex models but they dont do the micro receiver crystals on 40MHz I require. Wes-Technik in Germany does but was hoping to find a UK supplier or one that accepts online payments.
Antweight Database
yes me 2... wes-technik have a uk branch... BUT.. speaking to them they said it works out cheaper to order direct from them in germany.
awsome looking ant btw ;)
Antweight Database
I think Inertia-Labs has two...check http://www.inertia-labs.comwww.inertia-labs.com. I might be wrong.
Team Gore
Antweight Database
This is an update to ICant, it is now almost finished for rrc5, http://s4.invisionfree.com/Antweight_Forum/index.php?act=Attach&type=post&id=626306http://s4.invisionfree.com/Antweight...pe=post&id=626 306
looks a little like razer :P . It is now slower than it was but should do better.
Antweight Database
the weapon for our ant is done. See profile
Antweight Database
Antweight Database
oh, and for the rest of the robot see my profile :D
Antweight Database
Antweight Database
The name will be: Malenkaia Baba Iaga.
Translated it reads as Little Grandmother Yaga.
I would have written the name in Cyrillic but this forum does not allow for symbols text.
For more explanations check out some Russian fairy tales.
Antweight Database
When extrapolated to a heavy. A moving mass of 45 kg diameter 1.6 m powered with a 50 kw motor. Running at 13 krpm. And thats the weapon alone.... Ants are fun, when you could enlarge everything...
Antweight Database
perhaps you should mario :)
Antweight Database
Malenkaia Baba Iaga
Babeth, you really have an appetite for unspeakable names, i was thinking in the line of Super Mario (aka SM) :)
Antweight Database
Go read some Russian fairy tales and youll know why I love some of those characters.
Kashei Bessmertnye (our featherweight - still under construction) is also one of those more interesting personas in a Russian fairy tale (the one about the Phoenix).
At least they dont have trademarked names that would get me into legal trouble.:wink:
And if you really want to know... both are very evil magic-wielders.
(We found out yesterday that Marios niece has a fur dog-like toy called Pericles. Who said you cant have fun with history ?)
Antweight Database
at least Kashei is speakable, ill just call the ant Baba Iaga.
Antweight Database
Whats wrong with Malenkaia Baba Yaga ?
You know my motto: the smaller the robot the larger the name.
Antweight Database
Robot - No name yet- Was Jonslaught- Now im involved we have to put Dave in there somewere:)
Speed - slowish
Power - 4.5v nimhs
Drive - Acoms As-12 geared up by 1:4
Weapon - 360 degrees of lifting/crushing titanium scoopy-stabby thing
Armour - carbon fibre/titanium/Poly prop
Status - Half built- need some desent cheap batteries
Anyone know of some good small batteries? Sorry, im new to the Antweight world and my team mate Jon hasnt fought an antweight for 2 years so were both out of touch with the Ant world:sad:.
Antweight Database
http://www.Technobots.co.ukwww.Technobots.co.uk and use their NI-mhs
or
http://www.indoor.flyer.co.ukwww.indoor.flyer.co.uk and use their Li-po, remenber 2x Li-po cells = 6x Ni-mh cells in terms of voltage.
