Hi,
With the champs coming up I have started my last minute panic so instead of starting lots of threads I'll put my questions here and if your lucky you may even get to see pics or even a video of my bots once I'm back from holiday!
But first the questions;
1) what rate can I charge a 12v Nicd 2200mah or 2400mah battery?
2) can I charge 2 of said battery in parallel so I can change both batteries at once between fights?
3) if I've got a 11.4 4000mah 25c lipo battery don you think I should use a 100A fuse or a 80A fuse (I'm using 2 drill motors and speed 900 replica)
Thanks :P
