appart from buffer tank which i already know about? what are the variosu different ways of getting the most out power out of a LP system?
High flow rate (correctly sized tubing and a valve with high flow rate) , using quick exhaust valves , having a large bore , smaller pipe going from main tank to buffer to help reduce co2 cooling which will decrease pressure and geometry of the flipper (leverage etc.)
were can i get good flow rate valves?
matt, i have explained all this to you twice over now. why bother asking if you're not going to listen to what people say..
i lost the file that contained all the info you gave me and was unable to retrive it. this time though it shouldnt be an issue
At the shop of course.Quote:
Or the valve fairies, but i've heard they can be difficult to get in contact with.
ill try my luck with the valve faires :lol:
But, yes i have been told this info before by jonny, but im crap at retaining info unless its wirten down infront of me. im just after a reminder really, going on the third time lucky theory :lol:
