How do you do it?
The question I have is how do you do the following. From my link I have the wires going to a terminal block. However at the other side of the block I have to connevt three 14awg wires going to three escs. Two for drive one for weapon. How do you connect the three wires both posotive and negative to the link?
Re: How do you do it?
Terminal blocks? Solder? Deans? O rings and bolts?. Three 14awg cables are just to big for the terminal blocks
What rating terminal block are you using? because the higher the rating the bigger they are.
If you can't get hold of some bigger ones solder all three wires to one wire, heatshrink it (or any sort of electrical insulation really) and screw that into the terminal block.
Hi,
I did solder the three into one, it was just a tight fit. I've attached the wires via a o crimp . Should hopefully be it now.
