can the switch for my robot be a toggle switch?
what swich?
if you mean the link ...then no
the power switch cus u need a link a power light and a switch?
the power switch ie the on and off in a robot is the link
You don't have to have a switch. Most people just use a link to turn their bots on and off.
TBH it's just something else to break/turn off your robot.
If you insist on having one though try using a key switch as this is unlikely to be toggled through impact,
You could use toggle switch for power, but the battery live (,+, positive, red, whatever) must go straight to a removal link - basically wire loop with a connectors.
The reason for it is that the link can be pulled out in the event of an emergency (robot stuck in forward drive, electric shock, axe in leg, whatever), creating a large gap in the power supply circuit .
it would be pointless to add another switch to the wiring just something else to forget to turn on, and another
weakness to any robot
