Very quick question... anyone have any idea of the stall current on a motor like this?
on a motor like what ?????? :?: :?: :?:
Hover over the word 'this' and it's got a link to it.
Better yet: http://secure.oatleyelectronics.com//pr ... ffb2546f21
tricky question, why do you need to know?
Using it on an axe and dont want to blow the electronics!
That motor I would say about 50-60 amps but I would not want to stall it for too long as it will damage the motor and anything on that circuit.
Thats alright the controller I was planning to use is rated at 60A continous 120 Peak. I'm trying to avoid stalling it but its an axe so might come up against some resistance. Pulse are only going be for about 2 seconds is that likely to do much damage to the motor?
I would advise against using a speed controller on any electric axe, just use some big relays, you dont need speed control and it will blow the speedo.
Re damage it is the sudden stop, that would do the damage, the motor is not designed to take those forces for too long. I would agree with Alan, relays coupled together to make a reversing contractor and a couple of micro switches would soften the blow for the motor on the axe arm movement limits. also they would be a little cheaper £12 for the lot!!
