What the best spot in wiring up to hock these into?
what do you mean by failsafe??? is it an actual added in failsafe for the radio gear or do you mean the power link
the power light and power link have to be next to each other somewhere than can be easily seen and preferred accessible from the most side possible . the link also has to be in a way so the person making the bots safe doesn't need tools to remove it.
hope this helps
alex
yep, i mean power link. what can be used as these or were can i get some?
id go for a deans connector some people find these fiddle but andersons are also widely used
you could use a bit of wire with the connectors soldered on insulated obviously
a link is basically a loop of wire which can be removed easily by the marshal
http://web.me.com/robochallenge/Robo_Ch ... rical.html
You can buy them here or just make them yourself.
my power LED seems to make the whole HDPE chassis glow blue which is pretty cool!
