Kingchristo Robot
Hello everyone well im going to try and do something abit different but not sure about a few things. I have been given a 50cc mini moto and i want to use the engine out of this to drive my robot but im unsure how i am going to get it to power each wheel individually can someone leed me the right way thanks
chris
Re: Kingchristo Robot
A manual clutch operated by a servo mechanism on each side of the robot is one of the few ways that jumps to mind. Either that or a differential that can be locked or allowed to slip on either side.
What weight category are you looking at using it in?
http://www.gbone1.force9.co.uk/rw99/pic ... ential.jpg
The differential used in one of the firestorm encarnations. There's a reason that no one else (as far as I'm aware) has used a similar setup, they are difficult to engineer!
A few other problems jump to mind with a mini moto engine,
- Being an engine it doesn't have a great deal of torque at low revs and so will always have a delay in getting a robot up to speed
- You will have to have a gearbox to allow the robot to go in reverse
- You will need to have a way of remotely starting the engine as it will most likely stall in the arena (believe me, I know how likely engines stall in a robot arena)
- You may have trouble running it at a competition as there aren't many venues happy to have internal combustion engines running due to the exhaust fumes.
The other possible way to use it would be to have a single powered rear axle and servo steered wheel at the front (mighty mouse style)?
viewtopic.php?f=164&t=3644&p=107087#p107087
