As you've probably read by now I've just picked up the pneumatics for Wheely Big Cheese. I just wanted an opinion from people on the safety of it and compliance with current rules.
The set up is as follows:
Two 2kg bottles (with lever arms) connected to a valve block to the high pressure pilot valves.
A connection to a regulator which then supplies two low pressure 3/2 valves and the dump valves
Low pressure valves supply the pilot for the high pressure valves
To start up the following procedure is followed:
Close dump valve
Remove locking mechanism
Walk out of arena and activate two large servo's which operate the lever arms of the fire extinguishers
(No problems from me so far)
To de-activate the following procedure is followed:
SDe-activate the two servos
Open dump valve
This is where I think the problem is. If the servos fail to operate ort for some reason the valves on the cylinders fail to close then poetentially there is a need to dump 4kg of CO2 through a regulator. Should the regulator freeze then the system remains fully charged.
My question is:
Is this system acceptable with the addition of a high pressure dump valve or do i need to try and get some other form of opening/closing the bottles sorted out?
As far as I can see the way it is done now is perfectly safe as it means that there should never be anything in the system whilst anyopne is in the arena (except to disarm).
Andy
