Pro Peak Contellation Charger missing something
Hi all
Recently for Pug, I bought it a Pro-Peak Constellation charger from Technobots due to the fact that replaced the lead-acid battery for nicads. However though after getting in contact with David Weston, I had been told that Pro Peak chargers come with cables that plug into the red and black sockets labled output and at the other end are some bullet connectors, that right? Well I got the charger with just as itself and 2 crocodile clips and no cables that connect the charger to the batteries. If u can buy them seperately or if you can give me more info or help, it would be next appreciated, my next event is Wigan if you are coming
Cheers
Liam
Re: Pro Peak Contellation Charger missing something
same as mine, ive got 4mm bannana plugs that go to the supply, but there is 2 x 4mm holes in the front of the charger to connect to the batterys. you just need a bit of flex and a few 4mm bannana plugs and whatever to connect to your batteries. my last event i had a new charger and not enough plugs so i had to strip the insulation off and push the wires in the holes ! lol
good luck at wigan.
