http://www.mcmanis.com/chuck/robotic.../h-bridge.html
What does everyone think to this homemade speed controller?
I'm thinking of building one and am looking for opinions on it before going ahead.
Thanks, JB.
Thanks, JB.
youll need a pic programmer and knowledge of programming microcontrollers and writing code in BASIC or C++ or something. Should be ok for a light feather weight but nothing bigger. If you have the facilities to make it then go for it :), seems ok.
2 things to mention:
You will not save money building a speed controller yourself. Seems that way but doesn't work out in actuality.
That particular speedo can handle about 20 Amps. A good pushing featherweight can pull 25+. Also this has no current limiter so it'll let the magic blue/purple smoke out quickly..
I'm just doing it as a project because I find it interesting.
Also I will probably change the FET's in it / parallel them so it can take more current.
You might like to look at these.
http://homepage.ntlworld.com/barry.blyt ... ntrol.html
Regards Woody
I've had a look at those speed controllers and they look a fair bit better and safer than the one I was initially looking at building.
Just a thought, would doing what someone has done for the steering on his R/C lawnmower (taken an ordinary servo, used it to drive an H-Bridge and used that to drive a motor with mechanical feedback to the potentiometer on the servo board) work as a speed controller if I were to remove the mechanical feedback and the centre the potentiometer/ replace it with a pair of resistors to effectively make it a modified servo?
http://130.94.182.150/mowers.htm - the link to above R/C lawnmower.
The making of the giant servo is under converting standard R/C servos into monster servos
Yup ..seen that link ..in fact it's been up on my steering servo page for years. http://www.teamonslaught.fsnet.co.uk/wiring.htmQuote:
Originally Posted by daliad100
Here's a similar approach.
http://www.rc-airplane-advisor.com/elec ... oller.html
and another
http://trebor69.tripod.com/speedcnt.html
Feel free to play ...but consider this ...there are not many ( if any ) homemade speed controllers being used in Combat Bots.
Regards Woody
Thanks Woody.
This is going to be fun.
I use home made speed controllers:)Quote:
Originally Posted by woody
