help with a sabertooth dual 10A controller
Hi All
im using a dual 10A sabertooth controller in block of wood, but having trouble getting to grips with it properly
at times one trim is set to +28 and the other trim to +8, this was to just stop it moving on the spot when it wasn't meant to
i have changed this but the trim is still quite high and the whole robot goes to one side when i push fwd, i tested the voltages of each motor and as you would expect, the motor which 'turned' the robot was on 5.5v the other was on 5v
another issue is when i attempt a failsafe the drill motors begin to move and so the bot does also, it won't do any damage but in effect it just isnt failsafing
any help????
i have looked through the limited user guide and checked dimension engineering site for any help but couldn't see anything
thanks for helping
alex
Re: help with a sabertooth dual 10A controller
I'm assuming that your using a Spektrum TX + RX.
The Sabertooth ... or any other controller ...will not itself failsafe on loss of signal because the Spektrum ( other than a Spektrum - AR500 combo ) ALWAYS outputs a signal....you must bind / rebind the TX to the RX after finallising your TX's STATIC / OFF settings...thus saving them as the FAILSAFE position Signal.
i cant remember which way round it is but your sabertooth should be set 1 down the rest up, or 1 up the rest down, thats the settings i always used on mine.
I looked at the dimentionengineering website for the dip switch wizard. I tried some settings to get what you said. This is what I got:
Lead-acid, NiCd, NiMH -> radio control, or simulated radio control using a microcontroller -> radio and a receiver -> Mixed mode -> Linear
i have used drills, speed 700's with nimh packs in various robots, and a spektrum, and i had the settings as i mentioned above, never had any problems.
I'm using a Sabertooth 10A with NiCd's and I've got all the switches in the on position, but I'm using this diagram for setup. The website wizard seems to give some weird results.
http://dimensionengineering.com/tour...othRCdips.html
yeh i have all my switches on the 'on' side (not where the numbers are)
might try a different combe then
cheers
Also I'm using 40mhz radio on mine, not a spektrum.
